Shock hardware
Old Jan 26, 2023 | 11:54 AM
parrishbjj's Avatar
parrishbjj
Default Shock hardware
I'm working on an 82 shovel fxe. I don't have any hardware for the shocks. It looks like the bottom holes are threaded but the top ones are not. Can I just buy some bolts, washers and nuts? If so, what size bolts do I need and what grade strength?
Old Jan 26, 2023 | 01:07 PM
magnum45pete's Avatar
magnum45pete
you need the proper shock mounts or nothing will line up,
see this as a guide, many others are available on ebay or new from many after market dealers,...
Upper & Lower Rear Shock mount Kit Zinc Harley Shovelhead FL FX FXE 1973-1984 | eBay
Old Jan 26, 2023 | 09:17 PM
TwiZted Biker's Avatar
TwiZted Biker
Swing arm bolt is 1/2" fine thread, you'd have to measure to get the correct length, as Pete said the frame mount is dedicated, can't rig that gotta buy the correct stuff.
garywi
Mar 4, 2014 09:51 AM
hdnvn
Feb 25, 2014 04:06 AM
Sant6442
Sep 12, 2013 08:23 PM
nkauf21
Jun 22, 2010 04:28 PM
Casper
Jan 8, 2010 04:11 PM
