Ignition System Recommendations
Old Mar 8, 2023 | 04:54 PM
HellaGNARLY's Avatar
HellaGNARLY
Default Ignition System Recommendations
Right now I'm torn between Dyna 2000 and Rawhide. Anyone have any pros & cons or other recommendations?
Old Mar 8, 2023 | 09:08 PM
Spanners39's Avatar
Spanners39
I've only ever used Dyna and Twintek, never had cause to complain with either one. So long as you use one that doesn't require advance weights then you and the ignition system will grow old together.
Old Mar 9, 2023 | 01:56 AM
Bmp72's Avatar
Bmp72
Hm, I would go the other way. Dynatec S with the mechanical advance unit. This is the simplest setup, the dynatec replaces the points with a magnetically activated electronic switch. Will allow you to kickstart the bike. All the methods of setting the timing for points can be used.
Old Mar 9, 2023 | 07:08 AM
rockher_man's Avatar
rockher_man
Default Ignition
Dyna S and two 5-ohm coils.
American Prime Engineering Comp Master advance
weights.
Running since 2001.
No worries...
Old Mar 9, 2023 | 07:20 AM
cycleman11's Avatar
cycleman11
I believe the Dyna 2000 has the dip switch for kick start. What it does is allow the ignition to fire on the first revolution. When you have the dip switch in the electric start position it allows the starter to spin a couple of revolutions before it fires. Makes it easier on the starter.
In my mind the simpler the system the better. If you are changing the ignition changing out the coils along with new plug wires is a good idea.
Old Mar 9, 2023 | 07:50 AM
garystaven88's Avatar
garystaven88
Originally Posted by cycleman11
I believe the Dyna 2000 has the dip switch for kickstart.
Unfortunately it does not. It will need to be programmed with a computer from the pre-set 3 dead revs to 0 for reliable kickstarting.
The Dyna 2000 is a damn fine ignition. The Ultima programmable ignition is the same ignition with slightly different ignition curves for much cheaper as well.
Old Mar 9, 2023 | 02:02 PM
HellaGNARLY
It seems like everyone is telling me 2000i. Just ordered it from JP Cycles. Thanks for input.
Old Mar 10, 2023 | 09:25 AM
ShovelEd's Avatar
ShovelEd
Running an 'early' Dyna on Old Blue with 2 coils and dual plugged heads.
No issues.
ZachE
Evo Era Parts
Dec 8, 2015 04:20 PM
t150vej
EVO
48
Jul 23, 2012 07:39 PM
markymark02
Dec 15, 2008 06:26 PM
js124
Aug 10, 2007 02:10 PM
Draco
Apr 12, 2006 02:21 AM
