Shovelhead starter solenoid problem
Old Mar 19, 2023 | 07:21 PM
Geneeus's Avatar
Geneeus
3rd Gear
Default Shovelhead starter solenoid problem
Hi folks,
This one is new to me. I have an '82 FXR and just finished putting it together. The engine and tranny were put in the frame by a local mechanic, and it ran fine. He returned it to me, and it sat for about a year. I then new wires to the battery, ground, starter solenoid, starter relay, and starter switch.
Here's the problem. When I energize the starter relay, the starter solenoid pulls in just fine, and the starter begins to turn. However, when I release the starter relay, the starter continues to turn. I had to disconnect the ground wire to the battery to stop it.
In the past, when I ran into a problem like this, It was because the starter solenoid was hanging up, and so if you reconnected the ground wire, the starter motor would start to turn again because the solenoid was still making contact. Banging on it with a hammer for a while not only got the solenoid to release, but worked out a lot of built-up frustration. <grin>
But every time I hook the ground lead back up, the starter motor doesn't spin unless I energize the solenoid.
I have checked and rechecked the starter solenoid wiring, and definitely have the starter motor wired to the short stud.
Any help would really be appreciated.
Geneeus
Old Mar 19, 2023 | 07:30 PM
84 Shovel's Avatar
84 Shovel
Are the spark plugs in the motor? With the plugs out the starter is more prone to not stopping. Also make sure the battery is fully charged, a low battery can contribute to starter run on.
Old Mar 19, 2023 | 07:36 PM
wolfryder's Avatar
wolfryder
Default starter solenoid
make dam sure the battery is fully charged ask me how i no!!
Old Mar 19, 2023 | 07:41 PM
TwiZted Biker's Avatar
TwiZted Biker
Low battery charge, arc welding the contacts and probably the underbelly ground strap is either gone or cruded up.
Old Mar 19, 2023 | 07:45 PM
Geneeus's Avatar
Geneeus
3rd Gear
Yes, all four plugs are installed.
Old Mar 19, 2023 | 09:19 PM
Mustbefamous Jr's Avatar
Mustbefamous Jr
You said all new wires?
I would check that everything was wired correctly and half the time what was on the bike can be wrong to begin with. There was diagram posted on another thread that made a lot of sense and I remember it said something about preventing the starter stuck on
Old Mar 20, 2023 | 06:54 AM
tld6008's Avatar
tld6008
I believe JohnZZ posted this awhile back in case you need it
Old Mar 20, 2023 | 07:30 AM
chopper_man's Avatar
chopper_man
2 things,
Low battery, can actually cause the plates to essentially weld together and not release. Been there, done that.
Cables backwards on the solenoid. Long stud to the battery (or starter relay), short stud to the starter. Again, been there, done that!
Old Mar 20, 2023 | 10:00 AM
Racepres's Avatar
Racepres
2 things,
And.... The Very Most Likely...
Old Mar 20, 2023 | 10:51 AM
panz4ever's Avatar
panz4ever
How old is the solenoid? Could be hanging up on the inside. They make rebuild kits for them (at least for the FLH models). Maybe pull it and test it?
marc177s
Shovelhead
13
Jun 25, 2018 06:47 AM
garystaven88
Electrical/Lighting/Alarm
Oct 25, 2015 11:39 AM
xBigMarkx
Ironhead
Jun 16, 2013 07:07 AM
Garry81FXB
Shovelhead
21
Mar 27, 2013 02:57 PM
lennox5024
May 23, 2006 02:21 PM
