68 shovelhead valve key
Old May 31, 2023 | 05:26 PM
Jdizzy's Avatar
Jdizzy
Stage II
Default 68 shovelhead valve key
Says in the HD manual "spaces between key halves must face front and rear of engine on intake valves" what exactly is this orientation and why?
Old May 31, 2023 | 05:49 PM
Racepres's Avatar
Racepres
Never heard "Key" thinking maybe they talking Valve Keepers??
Old May 31, 2023 | 06:14 PM
joe40x's Avatar
joe40x
1/2 of the keeper is called a key. Each valve takes 2 keys.
Old May 31, 2023 | 06:21 PM
johnjzjz's Avatar
johnjzjz
Looking at the head from the right side of the engine it is thought a hemi design with the valve Keys opening at 3 o’clock as well as the rocker arm pad center
the load is spread across the valve - if its at 12 o’clock looking at it from the right side the load can rock the keys as spring pressures are not hi - on the seat pressures - now i never seen one come out but i have seen wear on the retainer taper - does it matter - who knows - as i said never seen one come out and never really spent the time to investigate this long term — but someone did and thats y
Old May 31, 2023 | 09:12 PM
Racepres's Avatar
Racepres
I guess I was taught that the "split" should be perpendicular to the front rear axis... ie front to rear... not side to side...Are they like that after ya run yer Engine???? Not exactly... No... Exactly like the Very Best truing job on the flywheels.... Wanna pull yer hair out????
Old Jun 1, 2023 | 01:39 PM
MarkSG's Avatar
MarkSG
I thought valves rotated a small amount while running. If one quits rotating it will burn. So it seems the keepers would rotate wit the valve and spring retainer.
Old Jun 1, 2023 | 03:08 PM
johnjzjz's Avatar
johnjzjz
Harley and Indian never did that - bbc chevy and small blocks did that and others it did not do whaat they thought and destroyed many engines
a rotating exhaust valve at 1600 degrees will bring the heads valve seat into a puddle - and it did just that
still valves at the time some one in the know if you asked him would have told you all the reasons it was Going to work - but it was 100 years of still valves that did work and still do today
Old Jun 2, 2023 | 06:38 AM
MarkSG's Avatar
MarkSG
I am more recently familiar with Lycoming engines. Lycoming and Continental use a rotater cap to rotate the exhaust valves.
When I google it
Most valves in an operating small engine rotate about the valve stem axis at varying rates. Valve rotation has an overall positive effect on valve life. Rotation provides improved temperature distribution in the valve head and a mild scraping action that cleans the valve interface of any crushed combustion deposits.
I assumed Harley did as well.
Old Jun 5, 2023 | 06:41 PM
johnjzjz's Avatar
johnjzjz
Not that i have ever seen 20 different motorcycle manufacturers do a rotating valve - small engines are throw away for the most part its cheaper to get another new one then to fix an old one - plus a small engine usually is at a 1/2 engine speed
i have seen the damage that was done on chevy engines from turning the valve - unlike small engines its not a big deal very light valve spring and super mild cam shaft and almost no compression
Old Jun 5, 2023 | 10:02 PM
Racepres's Avatar
Racepres
In my minimal experience, I see valves rotate some bit, even if it is Not a Design Feature... good??? Bad??? I consider it a Simple Fact...and deal with it... or Not
Edit; If the Remac says my springs are in (my) spec.. I'm Good!!!!
evangenj
Engine Mechanical Topics
Jun 13, 2023 08:05 AM
MikerR1
Nov 15, 2016 07:57 AM
woodw03
Shovelhead
Oct 24, 2014 09:50 AM
shovelhaid
Shovelhead
Feb 17, 2008 02:11 AM
bhollis
Classic
Sep 19, 2007 12:49 PM
