Front Turn Signals
Old Sep 14, 2023 | 07:29 AM
Racepres's Avatar
Racepres
Originally Posted by RANGER73
Curious as to how you're planning on popping that in from the inside?
Absolutely from inside.. a perfect place for Seal-All IMO
@oldtrucker I would be Interested in a Couple of those...I can think of a couple Uses!!!
Old Sep 14, 2023 | 08:26 AM
RANGER73's Avatar
RANGER73
Doesn't look like the reflector part inside is removable in the picture.
In which case it'll need to be drilled large enough to get the lens through, which would be good for light transfer too.
Old Sep 19, 2023 | 06:47 PM
oldtrucker's Avatar
oldtrucker
Simple, take the lens and bulb out, drill a 3/8ths inch hole dead center, mix a bit of clear epoxy adhesive, push indicator thru hole into adhesive and BAM! done.
Old Sep 19, 2023 | 06:49 PM
oldtrucker's Avatar
oldtrucker
The big part is inside the light so that with clear epoxy it is sealed an will look like the top picture.
stampde
Sportster S
Jun 27, 2023 09:16 AM
At_m_man
Electrical/Lighting/Alarm
Oct 1, 2011 07:58 PM
Dringo
Aug 26, 2009 10:18 AM
Tattooedlife
Jul 20, 2008 01:57 PM
bullcity
Dec 8, 2007 05:31 PM
