Clutch hub lining
Old Dec 11, 2023 | 02:32 PM
  #31
Redrodyankneck's Avatar
Redrodyankneck
Originally Posted by MarkSG
OK follow up.
On the Ramjet retainer!!
It looks like the only advantage would be if the chain is not running true the hub would walk out.
Mine seems to be aligned well and clutch works as smooth as the Twinkie.
Glad you don't need one. Since the hub in not locked in place it's a matter of design not execution. Add the RJ retainer, which has 3 diff clearance options, and the hub can't put pressure on the clutch discs thus finding neutral is easy even when stopped.
Old Dec 11, 2023 | 02:37 PM
  #32
Redrodyankneck
Originally Posted by john lee
if i had known now that i didnt know then i would not have used the big fix that came with the belt drive kit i would have stayed with the stock bearing cage my mc mech mate had to bore the shell out. although ive had no real problems exept getting neutral at standstill. i just tap it in neutral coming to a stop. my harley mech says thats normal. he even checked all adjustments are correct while he had the clutch apart to replace the hub which had stripped threads. i dont know why but he put in a 5 stud instead of a 3. shifting is fine-smooth but with the derby cover off with the bike running and in neutral the whole clutch spins. is that normal ?
Normal, Think about it, the trans is in neutral and the clutch is engaged.
Old Dec 11, 2023 | 07:00 PM
  #33
john lee's Avatar
john lee
thanks thats my thoughts too
Cliffw
Aug 19, 2023 04:04 PM
nicoleelyssa
Jun 7, 2021 09:36 AM
Jeff Thomas
Feb 16, 2018 05:12 AM
Not E'nuff Harley
Nov 6, 2016 08:46 PM
berndog
Shovelhead
17
Oct 5, 2012 06:58 PM
