Shovel is beating me down...
Old Jul 2, 2024 | 08:00 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Forgot the link for cooling spray:
Amazon Amazon
Tech Spray 1672-10S High Precision Diagnostic Freeze Spray
Old Jul 2, 2024 | 08:20 PM
Racepres's Avatar
Racepres
Battery??? 12.?? at rest
BTW New chiwanese **** is Still ****.. Triple check starter relay..My Oil lite is wired to the ignition breaker.. tells volumes about power to Start circuit. the accy circuit is something one can check with the damn horn, or brake lite!!
Old Jul 2, 2024 | 08:38 PM
Timberjkd's Avatar
Timberjkd
Originally Posted by johnjzjz
Most of the time its something very simple that just hides till you calm down and go find it
Yea probably is just need to step away for a few and think. Thanks.
Old Jul 2, 2024 | 08:42 PM
Timberjkd's Avatar
Timberjkd
yep. Everything is new. This was close to being a basket. Had the motor Rebuilt by an indie with new everything. Trans, kicker, primary...carb, new points, new dash & harness. All new stuff. Some rebuilt oem some USA and of course some was overseas stuff.
Old Jul 3, 2024 | 05:36 AM
johnjzjz's Avatar
johnjzjz
Points - the box will say in print made in the USA - but the parts are from some **** hole back alley
so you are buying a box that is made in usa
it has gotten a lot worse since joey mumbles
Old Jul 3, 2024 | 06:42 AM
eighteight's Avatar
eighteight
Originally Posted by old mago
If you're using NGK spark plugs and they have fouled , what i have found in recent rebuilds is that they dont like being fouled and cause all sorts of troubles even when cleaned up and reused........not bagging them as ive been a user of NGKs for decades and if using them on a motor that is already tuned probably not a problem.
Fairly certain fouled plugs don`t cause a "no crank" issue
Old Jul 3, 2024 | 08:15 AM
Racepres's Avatar
Racepres
"Tested used" Trumps "New" any day.. Again Chiwanese ****...is Still ****!!
A lot worse...certainly with Batterys and electrical parts
Reason I asked for the specific ... measured Voltage of Battery
Not that I know of either...But then...I gave up on NGK plugs a long time ago!!
Old Jul 3, 2024 | 10:36 AM
Timberjkd's Avatar
Timberjkd
Starter has power. Solenoid works properly. 12.4 on battery. Handlebar switch has power. Im going to check relay today. Can a circuit breaker under the tank be the issue? Heat? I would think if there was a ground/ short issue it would also show itself somewhere else as well.
Came in this am and bike fired right up with no problem. Has to be heat/ short related?? Idk. Again when it does it is after the bike is hot and it does not click or crank or turn over. Zero noise when I push the start button on bars. When cold bike fires immediately. Doesn't crank...or turn over just fires up like "Let's Go". Funny...when it wants to start its the best starting bike I've ever owned! 🤣
Old Jul 3, 2024 | 12:07 PM
Dmullins306's Avatar
Dmullins306
If you bridge the relay with your switch in the on position "Basically bypassing the starter button", does that engage the solenoid? I had a very finicky starter button that would work most times then at other times I had to push it at a very certain spot along the rim to make contact.
Old Jul 3, 2024 | 12:17 PM
johnjzjz's Avatar
johnjzjz
12.7 is normal 12.4 is almost dead
