Flasher relay trouble
1978.5 flh with oem equipment. 1156 bulbs.
1st time the problem occured I replaced the relay with the available small oem rectangular shaped relay from our favorite suppliers. It didn't last long.
2nd time I replaced with an automotive round relay from my local parts store. It didn't last long.
3rd time I used a heavy duty Novita brand electromechanical unit rated at 20amps and 12 lamps. This unit lasted about a year. Now that one failed!
I've been through all the bulbs for corrosion as well as the sockets for corrosion. I have not removed wires from the turn signals to check for corrosion because that task looks daunting. I will if anyone feels it neccesary.
So I ask politely, do any of my shovel friends have suggestions to fix this issue?
Motorcycle Motor Turn Signal Bulb Hyper Flash For Honda Kawasaki Suzuki Yamaha 12A 2Pin Electronic LED Flasher Relay - AliExpress 201355758
