Smoke
Old Nov 17, 2024 | 09:57 AM
1981 suprglide's Avatar
1981 suprglide
You are wrong. vice versa...
definitely white smoke is oil you're spaying mosquitos, sometime oil gets into the carburetor part of pollution control
Old Nov 17, 2024 | 10:15 AM
touchdown's Avatar
touchdown
If u don't start it muck could be condensation if it clears up in a few minutes ride it.
Old Nov 17, 2024 | 11:10 AM
Jd72chop's Avatar
Jd72chop
That sounds like it's a little dribbles out of the valve guides or seals. If it's a few puffs and doesn't foul the plugs I wouldn't even worry about it. On my shovelhead I'm battling smoke on deceleration. I think my heads are flat enough to get a good seal on the gasket and it's sucking oil into the chamber
Old Nov 17, 2024 | 06:23 PM
Spanners39's Avatar
Spanners39
Originally Posted by Racepres
Kinda...But...Should have checked the Oil when you Parked it!!!!
Nah, I usually need to pee so badly that I just leave it....
Old Nov 18, 2024 | 08:39 AM
Racepres's Avatar
Racepres
BTDT...But...It is Bad Habit checking oil in a Cold Harley!! Pee then Check Oil!!! While still warm/Hot!!
Old Nov 18, 2024 | 02:20 PM
Spanners39's Avatar
Spanners39
I know that, it was a joke, doesn't have to be accurate to be a joke Lol! I could redo it to...
"Preflight check list for a Shovelhead, read the factory owner's manual, follow the recommended procedures for pre-ride checks, top up oil and other fluids if necessary, ride according to the laws and statutes of your state."
Old Nov 18, 2024 | 03:19 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Obviously that's before the pit stop... Lol..
Old Nov 18, 2024 | 06:02 PM
Racepres's Avatar
Racepres
No...Don't do that... lets stick to "ensure she Turns Over...Starts and go... But... If yer Old as Me...Never miss an opportunity to Pee!!!!
Edit; I seriously Do Not believe anyone should "check fluids" on yer Harley pre-Ride!! Take the Car for that ****!!!
Old Nov 18, 2024 | 06:55 PM
98hotrodfatboy
Honestly, the only fluid level I check is how many beers I have in the saddle bag before I leave.. That's the pre-trip flight plan...
Old Nov 19, 2024 | 09:42 AM
Racepres's Avatar
Racepres
You been riding with me and my Bitter Half huh??
BTW...One of best parts of a Hack rig...plenty of room!!!
