Flasher switch
Old Jun 9, 2025 | 10:26 AM
76HDflh's Avatar
76HDflh
Default Flasher switch
Need to get a flasher toggle switch, part #67843-70. Part is no longer available from dealer, nothing on eBay. Tried goggle but nothing. Anyone know of a replacement part? Thanks.
Old Jun 9, 2025 | 11:28 AM
touchdown's Avatar
touchdown
well what are you working on????????????. I would look at Dennis Kirk or J&P
Old Jun 9, 2025 | 02:09 PM
Ken45's Avatar
Ken45
Here is a used one:
https://c3cycle.com/products/harley-...1UsNKw2z7WiySg
Old Jun 9, 2025 | 04:29 PM
76HDflh's Avatar
76HDflh
Bike in need is a 1976 FLH. Thanks Ken will look.
Old Jun 9, 2025 | 04:33 PM
76HDflh's Avatar
76HDflh
Checked out that switch, not the part I need. Mine is a 2 position toggle with 6 connectors. That looks like a spotlight switch.
Old Jun 9, 2025 | 04:46 PM
Ken45's Avatar
Ken45
This ?
https://www.ebay.com/itm/156879536345?
Correct nuts ?
https://www.ebay.com/itm/157032433788
Old Jun 9, 2025 | 04:58 PM
Racepres's Avatar
Racepres
I had that info at one time..something like 4 pole single throw..turning on 4 ways is exactly the same electrically, as Holding both handlebar switches!!
A difficult switch to find certainly..two cheap ones works...but mounting is questionable! Good luck.. mean time I will look see if I still have one in Stash!!
Old Jun 9, 2025 | 06:32 PM
76HDflh's Avatar
76HDflh
Thanks Ken45. Was looking at that switch, it’s one number off, says it’s for signal/spotlight nothing about flasher. My flasher 67843-70 gets its power from the lower two spades, the center 2 and top 2 spades go to directional. I think that switch uses the center 2 spades to receive power and depending which way the toggle is moved it will turn on power to the top2 or bottom 2 spades. I have to contact the seller to see if that switch 67844 is 2 positions on/off or 3 positions on/off/on. I just don’t know that switch.
Old Jun 9, 2025 | 08:30 PM
Ken45's Avatar
Ken45
I am wondering, If you can not find the right switch could you get a simple on/off switch that looks the part and make some little adapter harness to hook it up to the switch, you could leave the main harness as is with out modifying it.
Old Jun 9, 2025 | 09:05 PM
Illinois_Minion's Avatar
Illinois_Minion
I am assuming its and on-off-on switch (not momentary).
Like this??
on-off-on 6pole on-off-on 6pole
