Noisy valve lifter
Old Sep 10, 2025 | 01:50 PM
FXWG'80's Avatar
FXWG'80
Default Noisy valve lifter
Ticking valve-lifters
When the engine warms up, after 2-3 miles, the noise from the valves or the rocker box starts to make a lot of noise.
I drove another 5-8 miles, and the noise persists.
If I start it again the next day, it's the same for 2-3 miles, normal, then it becomes noisy.
I checked, and the oil is flowing (and circulating) into the rocker box.
I have an oil pressure gauge mounted on the crankcase, where the filter is (It's been there for 10 years).
The gauge activates, always for the first 2-3 miles. After 2-3 miles, the pressure returns to 0, no pressure is shown, and the noise from the rocker box begins.
I adjusted the push rods and checked the oil circuit.
I disassembled the oil pump, the gear box, and cleaned all the breathers.
The oil flows properly.
All checks were performed with the engine off, cranking it over with a kickstarter.
With the engine running, I checked that the oil was returning to the tank.
Any suggestions?
Old Sep 10, 2025 | 04:29 PM
crb2855's Avatar
crb2855
Did it just start doing it? What kind of sound is it a knock or tick?
Old Sep 10, 2025 | 05:21 PM
FXWG'80's Avatar
FXWG'80
Ticking
I rebuilt the engine.
I didn't replace the valves.
I replaced the rocker arm spacers, springs (OEM), and valve stem gaskets.
I've driven 100 miles so far.
The ticking comes when the engine warms up.
Old Sep 10, 2025 | 05:32 PM
john lee's Avatar
john lee
Originally Posted by FXWG'80
Ticking
bleeding out lifter ?
Old Sep 10, 2025 | 09:15 PM
Racepres's Avatar
Racepres
Likely... certainly if Imported! The Overhead oil lines are Restricted...Right??
Old Sep 11, 2025 | 02:06 AM
TwiZted Biker's Avatar
TwiZted Biker
Did you shim the rocker arms or left them as it came? HD changed the end play spec to .025" as acceptable to eliminate manpower and time on the assembly line, they get noisy if you don't shim down under .010" .
Old Sep 11, 2025 | 02:25 AM
FXWG'80's Avatar
FXWG'80
I cleaned and dried the tappets, drilled a hole inside, cleaned and bled the hydraulic lifters, and adjusted all the pushrods.
Yes, I replaced a couple of lifters. Hydraulic unit by Daytona (W&W)
The first thing I checked were the hydraulic points. Removed and cleaned them, they seem to be doing their job.
The ticking noise comes from both rocker boxes.
Old Sep 11, 2025 | 02:33 AM
FXWG'80's Avatar
FXWG'80
I don't remember the exact measurement now, but I replaced the spacers because the play was too much. With the new ones, I was within the specifications indicated in the Clymer manual.
But wanting to exclude the valve lifters, I think I'll have to measure the shims again
The loud ticking comes from both rocker boxes.
Is it possible that the spacers expand in the heat? (After 3-5 miles)
Old Sep 11, 2025 | 05:55 AM
Architect's Avatar
Architect
Listen to Twisted, but first throw the Clymer manual in the garbage and find a proper HD Factory Service Manual, hard copy or electronic. Clymer does not cover the nuances of different year motors like a FSM, good luck.
Old Sep 11, 2025 | 07:18 AM
crb2855's Avatar
crb2855
So the ticking started after the rebuild? Did you replace the cam or pinion gear? Also is it at all RPMs?
