tanks
Old Nov 8, 2025 | 04:49 AM
john lee's Avatar
john lee
Default tanks
just bought these shovel tanks. but they have evo screw in caps any clues. did they come out like that in a certain yr ? thanks
Old Nov 8, 2025 | 06:52 AM
AJSHOVEL's Avatar
AJSHOVEL
My 5 gallon fat bob tanks ('83 FXWG) have screw-in caps.
Old Nov 9, 2025 | 08:03 AM
Racepres's Avatar
Racepres
Previous to about '82 they were Bayonet... Also, the Indentations inside surface, will tell you if Pan or Shovel!!!
If Not "molded" they are Aftermarket!
Old Nov 9, 2025 | 07:12 PM
john lee's Avatar
john lee
there are no stamps and welded all the edges
Old Nov 10, 2025 | 06:45 AM
Racepres's Avatar
Racepres
^^ When the Snow melts, I will carry my Phone out and compare!!
Old Nov 10, 2025 | 09:56 AM
Mike1956G's Avatar
Mike1956G
As far as I remember, all 5-gallon FLH tanks up to and including the 1984 model year were equipped with the typical "bayonet" fuel caps, both fuel caps were different and not interchangeable.
I had both of my fuel caps engraved with the typical "Classic" lettering by a hand engraver who happened to have a small stall at a local festival.
It was very well done back then; the old gentleman usually engraved beer glasses by hand with a small diamond disc.
The original HD fuel caps were made of stainless steel.
The engraving turned out very well, I still have an old photo of it somewhere...
Mike
Old Nov 10, 2025 | 01:37 PM
john lee's Avatar
john lee
good man
Old Nov 10, 2025 | 01:45 PM
eighteight's Avatar
eighteight
That round "dent" just above the rear mount is a good indication of O.E.
Old Nov 10, 2025 | 02:16 PM
Racepres's Avatar
Racepres
As is the "relief" for the Frame casting.. collar looking relief... But..My O.E. Shovel tanks are more "hollow" at the front, where that one is Slab sided at the very front.. Maybe Later??? I have a later set...different Building...later Date!!
I will Venture that Not many Aftermarket outfits went thru the Bother to relieve (contour) the backside..If they did...they were generally a Quality piece.. I will try to remember to study harder when up to other farm.. til then...I would Not loose too much sleep over the Quality of your Tanks..
Edit; For Mike56G, The bayonet fillers (caps) were enough different side to side that the caps were Unlikely to fit ...unless sloppy indeed.. the Left, Non Vented, being a Shallow Bayonet...and the right, vented, cap having deeper reach to the bayonet end..
Old Nov 10, 2025 | 02:22 PM
Mike1956G's Avatar
Mike1956G
There's no need to philosophize about it for long; the 1979 Harleys were AMF products.
Just like the FLH-80 Classic. Retail price in Germany at the time: 17,900,- German Mark, a lot of money.
The workmanship back then was very questionable, the paintwork was okay, but the fairing, panniers and top case were painted terribly. Nobody would accept something like that today.
I complained about this to the German importer at the time, but received no response.
On the other hand, the motorcycle carried us across the whole of Europe multiple times, from the North Cape to North Africa, and did so repeatedly without a single breakdown.
A faulty ignition coil caused a breakdown, but we had a replacement with us.
The old Goodyear tires were indestructible, terrible in wet weather, but probably good for about 50,000 kilometers.
The FLH was the ultimate long-distance motorcycle, and it's no coincidence that I bought a second one used many years later.
Mike
