Starting issue
Old Nov 13, 2025 | 03:30 PM
Chile67's Avatar
Chile67
Default Starting issue
What are the symptoms on a bad relay switch on a 1973 FLH? Where is it located?
Old Nov 13, 2025 | 04:29 PM
pgreer's Avatar
pgreer
Usually a clicking noise or sticking closed so the starter doesn't stop when the button is released. Although there are several causes of these symptoms, so a full diagnostics is in order. Start with the battery, even if is is fairly new. Then check for voltage drop across the wire and relay under a load.
The original location of the relay is under the bottom of the battery box. Although I've seen 73 FLH with both the Ford and rectangular type relay.
Paul
Old Nov 13, 2025 | 04:49 PM
Chile67's Avatar
Chile67
Default Starting issues
Thank you Paul, it’s an intermittent problem
Old Nov 14, 2025 | 05:05 AM
TwiZted Biker's Avatar
TwiZted Biker
Check cable connection points and ALL ground wires to frame, they are notorious for causing multiple electrical issues.
Chile67
Shovelhead
Oct 14, 2025 10:40 AM
TravelinMann
Shovelhead
May 2, 2023 07:51 AM
RagtimeSAE
Shovelhead
Jul 25, 2012 08:45 PM
springer3
Apr 21, 2012 11:23 PM
copterman
Shovelhead
May 7, 2010 01:44 AM
