engine breather catch can
Old Apr 12, 2026 | 08:15 PM
Racepres's Avatar
Racepres
Originally Posted by Joe12RK
OK, you're picking nits. I meant the descending pistons push air out of the cases, and a PCV restrict air from flowing back, resulting in lower pressure than atmospheric. It this an advantage? IDK, perhaps it keeps oil inside the motor, or maybe adds 50HP?
But... Putting a vacuum pump on the Bottom End does Increase Horsepower...welp...actually, it lessens the parasitic losses!!
Old Apr 13, 2026 | 05:42 PM
old mago's Avatar
old mago
Originally Posted by Racepres
When you figure out how to Measure any Vacuum in the case, without a "Pump" please Tell about it..
No Way I obstruct the Breather, in Any Way.. May as well just plumb the breather into the Back side of your S&S air Box (look at those Threaded Holes that have Plastic plugs in them)!! Best way to Pass, and keep the Crankcase Well Ventilated.. (close as yer gonna get to a Vacuum) When done with testing .. Remove the line and drop it to the ground...and Stick Plastic plug in back of Air Cleaner!!! If you think Yer engine is Blowing excess Oil out Breather...Which generally indicates a Problem...Starting with Too Much Oil in Tank...and Progressing to Bad Ring Seal!! A drop here and there at Most...
I fitted this type of PCV taking the advice of johnjzjz when the bike had 8000 miles on the odo It now has 18000 miles and doing the service last week i unscrewed it to check the rubbery umbrella valve and all was good and very clean inside no oil build up at all and i would recommend fitting one to a shovel as my motor does not leak or weep any oil at all. So much so that i fitted a PCV to my Matchless G15 which is a factory norton matchless hybrid with a 750 norton atlas motor ,matchless frame and got the same results, no oil drips from breather hose and an oil tight motor. Unfortunately the backing pate on my S&S carb doesn't have the hole in it for the breather hose so iam thinking of purchasing the catch can and if my bike does get summoned for inspection i will then fit it.for the inspection..... Many thanks to your insight gentlemen
Old Apr 13, 2026 | 05:53 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The breather gear closes the breather when the pistons are on the upstroke.
No need for anything on the breather tube (except of course to keep it legal).
Would an inspector even know what to look for in a breather setup?
Old Apr 13, 2026 | 09:33 PM
old mago's Avatar
old mago
[QUOTE=Dan89FLSTC;22258544
Would an inspector even know what to look for in a breather setup?[/QUOTE]
I typed into google about the 1982 flh and the breather gear and it came up with reference to NSW EPA about the breather being plumbed into the airbox so i would imagine they would be on top of it. Generally our Australian Design Rules exempt motorcycles from engine emissions ADRs mainly i suppose because the fuel tanks are gravity fed and rely on a vented fuel cap as well as being oil cooled but if its been fitted from the factory it shouldn't be removed. .....silly really because the bike has a rear chain oiler which i use as its nigh on impossible to use a can of chain lube with the big chain guard and bags attached when Iam out and about in the countyside
Old Apr 13, 2026 | 09:52 PM
old mago's Avatar
old mago
@Racepres my bad my S&S backing plate does have that grub screw in it.........mmmmmm might just do what you said if i have to present for inspection
Old Apr 14, 2026 | 09:52 AM
Racepres's Avatar
Racepres
You Do You... Not for Me...I will submit, that if No Oil is present with that Setup..None would be there anyway...Unless you install the Umbrella Bassackwards.. the Pressure should be Released...Out...along with any oil with it..No Other alternative..
Old Apr 14, 2026 | 05:16 PM
1981FLH's Avatar
1981FLH
Do you get called in for random inspections in NSW?
Old Apr 14, 2026 | 07:08 PM
old mago's Avatar
old mago
yes .....Transport NSW who runs and sets rules for historic and classic rego called in 85 vehicles for 5 clubs in Sydney recently ...46 vehicles inspected,25 defect notices issued,16 vehicles identified with major defects including 6 deemed unsafe to drive from inspection site 19 vehicles deemed ineligible for historic or classic vehicle scheme and enforcement action is underway to cancel registration of 39 who failed to comply with the inspection direction, they didn't show up. Two club officials who are also authorised examiners with AIS (nsw pink slips ) have been referred for action against their AIS accreditation... All of these were cars, mainly idiots that rort the system...ie there was a photo of a 1965 rover with a bonnet scoop LOL it was even facing the wrong way They slapped a defect notice on the windscreen.....so basically the historic rego is for vehicles that are 30 yrs old and have no modifications ie stock as they left the factory and classic is for vehicles that have permissible modifications or allowed modifications that have an engineers report.
Old Apr 15, 2026 | 01:45 AM
1981FLH's Avatar
1981FLH
Ok that’s interesting, I haven’t heard of anything like that happening in the territory must check with my club at some stage, I actually don’t have an issue with the random checking when I lived in Victoria there were a lot of shitboxes getting around on club reg, most of them shouldn’t have been on the road no matter what class of reg they had.
Old Apr 15, 2026 | 05:50 AM
FL54's Avatar
FL54
No offense to our Australian brothers but that sounds like a totalitarian state. No such thing here. Where I live we don’t even have vehicle inspections of any kind. Once you get your special purpose or antique plate, you’re done. No annual registration fee either.
