Inner primary install
Old Apr 26, 2026 | 08:03 AM
76HDflh's Avatar
76HDflh
Default Inner primary install
They say no such thing as a stupid question so here goes! Bike is a 1976 FLH, I’m changing trans sprocket, replace seals. The engine and transmission are bolted down, when I reinstall the inner primary do I have to loosen the transmission or can the inner primary be bolted back in place since nothing loosened when inner primary was removed. Thank you for any assistance.
Old Apr 26, 2026 | 08:58 AM
Racepres's Avatar
Racepres
If same same primary ... it shouldn't be a problem..Hand fit, and ensure you Do Not force Anything.. certainly Not anywhere near the Ring at the alternator.. very easy to Break...then, yer Screwed!!
Old Apr 26, 2026 | 11:04 AM
Joe12RK's Avatar
Joe12RK
^^^ This, and check the inner doesn't rock at all, you don't know if the person who last had it apart did it correctly.
Old Apr 26, 2026 | 05:35 PM
76HDflh's Avatar
76HDflh
Thank you! Repairs and reassembly continue.
Old Apr 27, 2026 | 06:49 AM
Racepres's Avatar
Racepres
Yes...absolutely... If in any Doubt..I loosen all 5 Trans Bolts...then carefully fit Inner...when Inner is secure, ensure tranny is sitting tight to Mounting Plate...(if Not... Spacers are Required) then bolt it back down!!
PITA...but..
Old Apr 27, 2026 | 04:04 PM
old mago's Avatar
old mago
and if the O-ring is replaced, make sure its the proper one . The thin one not the thick one
Old Apr 27, 2026 | 09:03 PM
TwiZted Biker's Avatar
TwiZted Biker
Find enough problems with the old iron I do a full go over on them when the inner comes off. Loosen the front & upper motor mount bolts, check torque on the rears, feeler gauge the front for any gap and shim if needed, same with the upper. Loosen the trans, install the inner with the 4 motor bolts then pull the trans in with 2 of the studs. Get under and check the trans mounts for any gaps and shim to correct. Torque it all down. Be surprised how often things are out, and it does knock down felt vibration. Lot of nagging oil leaks and seeping come from the halves and mating points working against each other even with good gaskets and sealer.
jurgie
Nov 12, 2024 09:28 PM
Engine_oil
Dec 19, 2021 10:40 AM
Craigsameer
EVO
Nov 30, 2021 01:37 PM
harley2390
Touring Parts
May 5, 2021 06:01 PM
Strudy68
May 2, 2015 07:27 PM
