Help: FXE stop switch
This is my first post. I am writing from Italy and have a 1979 FLH.
Right now I am building/restoring an almost stock 1976 FXE
Basically I got a basket full of parts (almost complete bike) + engine and frame. Bought and boughtOEM electrical harness from JPcycles. Now all the wiring is done. I turn ignition and all the lights fork, but have a little problem with brakes.
I have a stop swith like this (noy new or chromed, just old)
http://www.jpcycles.com/productdetai...rch=fxe%20stop
What I understand is that it's a push off switch. The brake pedal has a plate that pushes that pin in the middle. When I press the brake, the plate releasses the pin and stop light is supposed to glow.
Now what happens is: pedal is pressed, stop light glows. As soon as the plate touches the pin when brake is releassed, I can see sparks between both and stop light turns off (position light is still on). After a couple of seconds i hear a loud CLICK (1 of the 3 circuit breaker under the seat) and stop light turns on again. pressing and depressing the pedas makes nothing. After few more seconds circuit breaker works again, stop switch works but sparks are seen, and CLICK again.
What can the problem be? How does the stop ligt swith work? just pressing the pin? does it ground through the plate of the pedal?
Thanks
Giancarlo
You can double check this by checking the switch’s continuity: Take an ohm or volt meter (if you use a voltmeter, you'll need a DC power source with a light bulb). Run one leadto one of the contacts, and the other lead to the other contact. When the pin/plunger is out completely (not pushed in), there should be continuity between the two contacts. When you push the pin/plunger in slightly, this shouldbreak the continuity/contacts.
Based on the above, the wiring should be: (important note: the switch does not use anything as ground, since the grounding source is taken atthe taillight/brake lightside ofthe setup) From the positiveside of thepower source (preferably from your ignition switch's on position - don't run this directly from the battery, and should bewith either a circuitbreaker, or fused, at 10 amps or less) to one of the switch's contact. Then from the switch's other contact, run a lead (wire) to the otherbrake light switch wiring (front or rear - wired up similarlybut so that either switch can/will operate the brake light), then run the final lead (wire) to your brake/tail lights – the tail/brake lights should have a ground wire, which of course grounds to your frame/fender). If you're not using the stock brake wiring leadsthat has the insulatedring terminals, make sure youuse an insulated ring terminalthat's the right size. Also make sure you use those little cardboard or plastic washers that came with the switch between the ring terminals and theterminal seats on the switch, and that nothing (bare wire or metal part of ring terminal) is touching and/or grounding out at or around the switch's connectors.
Best of luck and enjoy the ride.
anyway, problem solved, but not really know how. Actually before seeing the sparks betwenn the switch's pin and the brake pedal's plate, tha plate was in contact with the switch's built-in mounting bracket. While pressing the brake pedal, the plate was sliding right onto the bracket surfare..and there were also sparks. That meant the switch was grounding everywhere. After reading your first anssers I doublechecked all the wirings and they are OK. I took the switch off the bike and sprayed the inside with WD-40, pressing the pin a few times. Installed it back. It's not grounding anymore and works fine. Now the front brake swith doesn't work. I just need a new one I guess, because the stop light works when the 2 leads touch each other, but not once they are installed in the swith.
Anyway, thanks again!
G
