Engine Oil Leaks, 72 FLH
Old Oct 29, 2007 | 06:12 PM
R Heisner's Avatar
R Heisner
Stage II
Default Engine Oil Leaks, 72 FLH
Any body got any secret tricks on how to set up Head Gaskets and Rocker Box cover Gaskets to keep them from leaking? I used both copper and the blue teflon gasketsbut the rear still leaks.
Old Oct 29, 2007 | 09:57 PM
pococj's Avatar
pococj
Default RE: Engine Oil Leaks, 72 FLH
Sounds like something is warped.
Old Oct 30, 2007 | 12:45 PM
powdercoater's Avatar
powdercoater
I agree. I'd take both heads to a good machine shop to get them checked.
As far as the rocker box gaskets go, get the more expensive JIM'S gaskets with the silicone bead. I had the same thing going on with mine and those gaskets fixed her up. Be careful adding silicone (RTV) yourself becuse it doesn't take much to cause lots of oiling problems when it squeezes into the top of your heads!!
cajun1957a
Shovelhead
Sep 5, 2013 12:59 PM
JHummel89
Shovelhead
Nov 7, 2011 07:07 PM
Steve_m
Exhaust System Topics
Apr 8, 2011 08:55 PM
matthew91672
Apr 3, 2010 06:38 PM
bigfish
Ironhead
15
Jul 6, 2006 01:34 PM
