stroker plates
Old Jan 25, 2008 | 09:37 AM
graultytc88's Avatar
graultytc88
Default stroker plates
Does anyone have experience with stroker plates on a 1200 shovel? I'm looking at a motor with these installed and I have no clue. Pros and cons?
Old Jan 25, 2008 | 11:12 AM
lplugw's Avatar
lplugw
Default RE: stroker plates
Once you stroke an engine past a certain point you must have stroker plates to lengthen the cylinder bore or your piston geometry (position of wrist pin hole to ring lands and skirt length) doesn't work or work well anyway. The extra travel of a stroker piston would either drive itself into the head or the skirt would hit the flywheel or you'd wind up with a piston so short it wouldn't last long.
I think they're usually 0.200" thick and I'll bet that engine has an S&S carb because those stroker plates raise the cylinders and open up the "V" , requiring a special intake manifold.
You'll have to find out what 'wheels are in there. Might be a nice S&S setup.
Another thing, are you sure it's still a 74" (1200)? If it's stroked it's not and the cases probably have been bored to accept cylinders with a 3 5/8" bore (big bores). Sometimes oversize pistons past .020 or .030 can be tough to get for the big bore strokers. Meaning you'd have to buy new pistons AND new cylinders if you need a ring job.
That's what I've figured out.
Old Jan 25, 2008 | 10:18 PM
graultytc88
Thanks Iplugw, dont know what kind of carb but I fugured on opening it up anyway if I got the motor. No I'm not sure of the exact displacement and neither is the seller, but it started out as a 74" not an 80".
Would it be right to figure that these plates were part of a package to stroke the 1200? It wouln't do any good to just have the plates right?
Old Jan 26, 2008 | 12:43 AM
nomad billy's Avatar
nomad billy
No graulty wouldnt do any good at all,just lower the compression.Must be an old kit,piston tech has improved by so much no need for em,unless its a big motor an they didnt last very long at all.
Old Jan 26, 2008 | 09:52 AM
graultytc88
Great, thats good to know, maybe I'll stay away from that one.
SKJOLD
May 26, 2024 08:32 AM
brad75raiders
Engine Mechanical Topics
11
Mar 7, 2018 05:32 AM
htrod9592
Exhaust System Topics
Mar 4, 2011 05:37 AM
bluezguy
Shovelhead
Aug 17, 2006 09:08 AM
SKJOLD
Jun 16, 2005 09:05 PM
