power to coil problem
Old Dec 19, 2018 | 01:53 PM
jimmyjennings60@gmail.com's Avatar
6th Gear
Default Weak spark after putting on new coil, on79 shovel custom frame and not factory wiring
I replaced my coil on my 79 shovel engine because of weak spark thinking that was the problem, but its still weak, the bike won't start, has new battery but can't check under load cause bike won't run, what should I check next, plugs are new but plug wires are old but check out OK with multi meter continuity? Any help would be appreciated.
Old Dec 22, 2018 | 08:27 AM
SparkyD's Avatar
SparkyD
Originally Posted by SirEagle
kill switch, if it goes bad you lose everything to the coil and those aftermarket switches sometimes are bad right out of the box
I replaced a few expensive parts before figuring this one out LOL! Expensive lesson
Old Dec 22, 2018 | 08:51 AM
1981 suprglide's Avatar
1981 suprglide
wow I had fire under my seat until I found out
the coil fires better with fourteen gage wire from the ignition
to the coil and another thing if the ohms are incorrect it won't fire in the case
of mine it will only fire on a 3 ohm coil and nothing else
Old Dec 22, 2018 | 09:08 AM
Racepres's Avatar
Racepres
Something is very wrong.... What [Exact] components???? Chiwanese maybe?? The size of the wire has very little to do with it... Big enough is... well big enough... More ain't any better...
Old Dec 22, 2018 | 12:31 PM
johnjzjz's Avatar
johnjzjz
you missed the part about he was hungry and they had hot dogs so they fit across the frame top and it seemed like a good idea at the time
Old Apr 28, 2020 | 11:06 PM
TotoYeshAyen Dalisay's Avatar
Stage I
Default 0V supply voltage to coil if connected, but if disconnected voltage is 10V
My 440cc swm gran milano motorcycle crank but not starting. I checked ignition coil, resistance is 1ohm. If I disconnect the coil, i measured voltage 10V, if I connected the coil, voltage is 0V. What could be the problem, I suspected ECU. I already checked all plugin wiring connections. Battery is new. Kill switch is ok. Fuel pump, horn, lights are running. Please advise.
johnmck
General Topics/Tech Tips
May 17, 2018 09:36 PM
Rkellogg
Shovelhead
Feb 11, 2018 06:42 PM
Skiprrrdog
EVO
18
May 23, 2016 10:26 AM
ncottrell2009
Ironhead
Oct 20, 2012 09:46 AM
hog4u
Ironhead
Apr 24, 2008 08:50 PM
