78 FL, Fork chatter-vibration.
Old Jun 19, 2008 | 04:36 PM
rstevenson's Avatar
rstevenson
Stage III
Default 78 FL, Fork chatter-vibration.
I have a 78 FL, from a stop or low speed roll if I accelerate or crack the throttle I get a chatter / vibration&nbsp\\;in the forks. You can visibly see the vibration down at the wheel. It appears to be strongest on the brake side, I recently replaced the pads and made sure the caliper wasn't binding on the pins and I made sure there weren't any issues with the wheel or bearings. It really didn't help much. Any ideas? Not sure where to start!
Old Jun 19, 2008 | 06:07 PM
megawatt's Avatar
megawatt
Default RE: 78 FL, Fork chatter-vibration.
I would start by checking the adjustment and even, perhaps, the condition of the steering head bearings if they had not been serviced in a while. Also check the fork tube pinch bolts and end caps for tightness.
stal94gt
Sep 9, 2018 01:07 PM
packey84
May 9, 2013 05:37 PM
BadPiggy
Jan 5, 2011 09:55 AM
roofer
Oct 3, 2009 02:53 PM
rstevenson
Jun 17, 2008 04:17 PM
