stator question
Old Oct 20, 2008 | 02:32 PM
shovel pat's Avatar
shovel pat
Default stator question
I need to replace the stator an my '79 fxs80 and found that they come coated and uncoated.
Can anyone tell me which is best and maybe why?
Thanks, Pat
Old Oct 20, 2008 | 06:40 PM
sqdealgeorge's Avatar
sqdealgeorge
Heat dissipation The coated ones hold in the heat ( so they say ) go with the uncoated
Old Oct 20, 2008 | 06:50 PM
shovel pat's Avatar
shovel pat
Makes perfect sence. Thanks for the heads up
Pat
Old Oct 1, 2021 | 02:00 PM
Ron Bizzle's Avatar
Ron Bizzle
Default Uncoated stator
I was just wondering about this issue also...having to replace my stator again. (I had a 600 watt Bluetooth speaker system hooked up and I believe it was pulling to much amps and fried the stator). Already replaced voltage regulator and that didn't
resolve the problem.
Old Oct 1, 2021 | 04:34 PM
carlgrover's Avatar
carlgrover
I believe I've read that the cycle electric brand stator is a pretty good one. Don't know what brand you priced up there but you might have a look at them.
carl
Old Oct 1, 2021 | 04:56 PM
Redrodyankneck's Avatar
Redrodyankneck
carl
I changed out my stator in my 83 FXR about 1.5 years ago and was able to order an HD stator ( correct part Number for my bike). It wasn;t old stock because they were back ordered through HD and I had to wait an extra week to get it.
Old Oct 1, 2021 | 08:16 PM
Racepres's Avatar
Racepres
carl
Yes, and last I heard, made in USA.. Worth a look, based on all the great feedback
Old Oct 2, 2021 | 07:30 AM
crb2855's Avatar
crb2855
Hi, If that was pulling 600 watts, divide 600 x 12.6 and that's how many amps its pulling which comes to around 47.6 amps. 47 to 50 amps the battery can handle that for a while but most motorcycle charging systems can't keep up. I think the rule of thumb you need about a 3 amp overhead to keep a battery charged. that includes all system requirements, lights, ignition, etc.
Old Oct 2, 2021 | 11:32 AM
Ron Bizzle's Avatar
Ron Bizzle
Default 600 watt amp.
[QUOTE=crb2855;20211529]Hi, If that was pulling 600 watts, divide 600 x 12.6 and that's how many amps its pulling which comes to around 47.6 amps. 47 to 50 amps the battery can handle that for a while but most motorcycle charging systems can't keep up. I think the rule of thumb you need about a 3 amp overhead to keep a battery charged. that includes all system requirements, lights, ignition, etc.[/QUAmp.
I'm pretty sure I burnt up the Stator.....l'll post pictures of it once I start tearing into this project. (Monday morning)
Old Oct 2, 2021 | 02:50 PM
johnjzjz's Avatar
johnjzjz
I have never seen any difference in how long one lasts - coated or not coated - but the china run of the mill is junk - some company’s sell USA made stators and they are way better then the typical bike shop everyone sells stator - cycle electric sell one but they over charge for everything they sell no matter what it is
just so you know
