cowpie or rachet top
Old Jul 18, 2009 | 08:49 AM
hogdog76's Avatar
hogdog76
4th Gear
Question cowpie or rachet top
Hey Guys Ineed some advice I have a 74 shovel flh and a rachet top tranny thats in rough shape never been opened some bushings are wore it jumps out off gear leaks and on and on. I know a guy that has a nice all chrome rebuilt cow pie tranny. He wants 250.00 and my tranny. Is this fare and whats the better trany is the gearing differant? Could really use some help here Thanks
Old Jul 21, 2009 | 05:02 PM
sqdealgeorge's Avatar
sqdealgeorge
AND THE ANSWER IS NO ! Do not get into a cow pie trany What is a cow pie ??? The ratchets were the best You can still buy a new one for less then $1300 HD did the cow pie to accommodate the rear belt drives (bad seals etc etc )
Old Jul 21, 2009 | 07:02 PM
FilthyLucre's Avatar
FilthyLucre
I prefer the ratchet top to the 79 and later version. I've used both. It has a few things I don't like about it. You can't feel neutral like you can on the older transmissions, you have to depend on the idiot light. The shift linkage wears out much sooner than the ratchet style. You have to use the 79 and later oil tank/clutch cable bracket as well as the later clutch arm. As far as gearing it depends. If it is from an FX it will have a close ratio set, from an FL it should be the same as yours. Also depending on the model and linkage it might shift backwards. A FX transmission will not have a transmission drive built in and you will have to consider a front wheel speedo. Considering all the above $250 for a rebuilt transmission to get you back on the road is not bad. You could rebuild your own tranny for about the same price unless you have some serious damage. I would open yours and check before I gave up on it.
Old Jul 24, 2009 | 01:59 PM
RHPAW's Avatar
RHPAW
I got a cowpie in my FLH. It's a snarly collection of levers, almost like a Rube Goldberg mousetrap. But, at 160,000 miles plus........no complaints.
If it ever stops working, I will consider a ratchet top. You can't even find many cowpie parts in the J&P catalogue.
bentparts
EVO
16
Dec 15, 2017 09:39 AM
Darrell07FLHR
Shovelhead
Sep 29, 2015 11:57 AM
4ever2wheels
Aug 9, 2013 10:32 PM
Joey Bruce
May 21, 2013 05:42 PM
38knuckle
Shovelhead
22
Jun 13, 2008 01:40 AM
