Timing problem
Old Oct 27, 2009 | 06:41 AM
TN Mountaincruzin's Avatar
TN Mountaincruzin
Stage III
Default Timing problem
I have a 67’ FLH Shovelhead and have come up with a couple of conflicting manuals about setting the ignition timing. First figure (1) appears to be at TDC or 5 degree BTDC of F cylinder. Figure 2 states that this is 35 degrees and the three manuals indicate either, at 2,000 rpm, idle, or no indication at all. So, my questions are: is the mark with the dot and vertical line 5 degrees BTDC or TDC? Second, it would make sense to me that the second figure would be 35 degrees BTDC at 1500 (single vertical line) or more rpm’s for maximum advance, but all books are not clear on this for the bike. Sorry, site would not allow figures. Figure 1 is a solid dot to the left of the vertical line and figure 2 is just a vertical line. Thanks.
Old Oct 27, 2009 | 06:46 AM
prodrag1320's Avatar
prodrag1320
use the single line (35 degrees)
kirby
vee twin racing
Old Oct 27, 2009 | 11:15 PM
FilthyLucre's Avatar
FilthyLucre
The line is the one you want, that is the Advance timing mark front cylinder. Here is the Service Bulletin from 1969.
Old Oct 28, 2009 | 09:20 AM
mayanruben's Avatar
mayanruben
Default shovel
Single line on the slab, keep it simple..run it for a bit, pull the plugs..then either advance or retard..nothing, nothing sounds as mean as shovel..
ruben
Attached Thumbnails Timing problem-66-shovel-5-000.jpg   Timing problem-72-shovel-5-000.jpg   Timing problem-my-ride.jpg
Old Oct 30, 2009 | 07:00 AM
TN Mountaincruzin
Stage III
Default Thanks
Thanks for all the info. I set the timing at 35 degrees @ 2,000 RPM, runs great!
Old Oct 30, 2009 | 07:20 AM
prodrag1320
nice scoot!! with the dual plug heads,you dont need as much avdance,run it about 3-4 degrees retarded,youll pick up some more power
kirby
kimu koo
Flathead
Aug 5, 2017 06:49 AM
walteria13
Ironhead
22
Oct 5, 2011 08:30 PM
firsthd
Welcome Area Only
14
Apr 26, 2011 12:07 AM
Green Man
Apr 16, 2011 09:41 PM
straydog13
Ironhead
Oct 9, 2009 02:02 PM
