Stuck motor
Old Mar 11, 2010 | 07:58 AM
ttikalsky's Avatar
ttikalsky
Default Stuck motor
Working on restoring the bike and can't get the motor to turn over. New battery, lights come on, starter engages but won't turn motor. Possible to turn motor over to verify pistons are not stuck?
Old Mar 11, 2010 | 08:53 AM
FLYING's Avatar
FLYING
Sent you an e-mail, with re: stuck motor as I need some info as to when it actually was run last. I know it was stored for a while so let us know how long.
Old Mar 11, 2010 | 08:57 AM
FLYING's Avatar
FLYING
The safe way to turn it over would be to remove the spark plugs,jack up the back wheel , put it in gear and try to turn it over that way,if it does not move spray (soak) the cylinders down with WD-40 for a few days and then try it again. If the rings are stuck you will need to get the pistons to move for dis-assemble and repair anyway.
Old Mar 11, 2010 | 07:58 PM
ttikalsky's Avatar
ttikalsky
Motor turned over with spark plugs removed. Engaged the starter and tapped the starter motor with a hammer and she broke free! Motor spins with no odd noices and have good spark at the plugs.
Andrew Buckley
Apr 2, 2019 06:49 PM
Vince2272
Jun 9, 2016 04:12 PM
grieker
Oct 13, 2014 08:03 PM
JimmyT1950
17
Aug 6, 2013 03:35 PM
syono1981
Exhaust System Topics
15
Apr 18, 2011 11:06 AM
