Old tank liner chipping...
Old Mar 16, 2010 | 08:09 PM
mpetrie610's Avatar
mpetrie610
6th Gear
Cool Old tank liner chipping...
OK, some time in the bikes past someone put tank liner in it. It's a silver finish lining. Perhaps the surface prep was not done right or perhaps it's just tired, but it's flaking.
I read numerous suggestions about shaking the tanks with bolts, nails, BB's, etc., in them to remove the old liner. I chose Pellet gun pellets because they have corners and edges. Shook each tank for quite some time with little result. Busted loose the already flaking pieces is all.
I purchased Kreem to reline the tanks but understand you can't reline until "all" the previous liner is removed. So, how do you remove "all" the old liner? Some I can't even scrape off with a screw driver!
Any suggestions would be appreciated.
Old Mar 16, 2010 | 09:10 PM
78fxs78's Avatar
78fxs78
Try some Acitone or MEK. Let it soak, either are strong solvents, highly flamable. If you get it clean and its not rusty, I wouldn't seal it. I know more people that always have problems so they leave'em bare. My '01 Twinkie didn't have anything from the factory. My Low Rider still has original Grey coating.
Old Mar 19, 2010 | 12:14 PM
FLYING's Avatar
FLYING
I have never relined a oil tank and would not recomend it.Throw it out and replace it before you wish you did .
Old Mar 19, 2010 | 02:27 PM
panz4ever's Avatar
panz4ever
Alway taken my tanks to a radiator shop and had them clean them out. Come out extra clean and look brand new. They will also pressure test them for you.
Might want to check around on using the Kreem. Not all have had good luck with it. Just replaced a set of 25 year-old aftermarket tanks that had not been lined. For the age they held up well. Stock HD tanks should not need to be lined.
Old Mar 19, 2010 | 04:03 PM
mpetrie610's Avatar
mpetrie610
6th Gear
Default Radiator Shop
So, does the radiator shop chemically clean the insides preserving the paint or do they cook them taking the paint off as well?
Thanks,
dynawg1
Feb 13, 2022 03:00 AM
FL54
Panhead
May 11, 2013 11:28 AM
nazareth27
May 15, 2012 10:26 PM
claaster
Exhaust System Topics
Jun 26, 2009 08:10 PM
freekdawg1200
Aug 25, 2008 05:11 PM
