190 main jet
Old Mar 18, 2010 | 03:22 PM
j404ski's Avatar
j404ski
Default 190 main jet
Does anyone know the drill size & diameter of a 190 main jet in a CV carb? I've got a 165 in mine and it's coughin' and spittin' the carb off.
Old Mar 18, 2010 | 04:09 PM
Neil74's Avatar
Neil74
That depends what carb your working on. S&S uses decimal, if 98 jet = .098 inches. Japanese 190 would be 1.90mm=.0748 inches. Your regular drill set will sometimes have correct drills, unless in between size. For instance a 3/16 drill = .1875in., and a 13/64 = .2031in. Your wire gauge size drills an 11 = .191in and a 12 = .1890in. If you have drills available use them for a plug fit in your 165. Sorry I can't help more but I know nothing about a CV carb To convert from metric to decimal 1.90 x .03937= .0748in. to convert in. to metric .0748 divided by .03937 = 1.90mm .03937 being your constant Never noticed no division sign on a keyboard
Old Mar 19, 2010 | 01:10 PM
j404ski's Avatar
j404ski
thanks Neil!
Old Mar 19, 2010 | 08:35 PM
78fxs78's Avatar
78fxs78
Hand drilling isn't real precise anyway, you may want to go a little smaller first, then try it, 190 seems awful big for a CV, OK for a butterfly.
Old Mar 22, 2010 | 06:38 PM
j404ski's Avatar
j404ski
that's what I've read other guys recommend using for converting to a CV carb on a shovel so I figured I'd try it.
Old Mar 22, 2010 | 07:45 PM
Neil74's Avatar
Neil74
This link seems to support the 190( .0740) jet, but for a 88 twin cam, I'm not familiar with either the carb or the motor,maybe one of the Harley Mechanics will chime in
https://www.hdforums.com/forum/fuel-...ggestions.html
intensecombat
Carburetor Related
Apr 19, 2015 08:20 PM
Romprunner714
Carburetor Related
Jun 16, 2013 10:12 PM
nickdv9
Jul 11, 2007 10:01 PM
Gadgetech
Exhaust System Topics
Aug 27, 2006 03:35 PM
HDF Tech
Carburetor Related
Jun 25, 2005 05:37 PM
