79 flh
Old May 16, 2010 | 12:33 PM
allegiance85's Avatar
allegiance85
Stage II
Default 79 flh
hey guys have a 79 flh and just bought a (dome style clutch) that is the only name i could find for it. It is a aftermarket and i can not figure out how to adjust it. If anyone could help me out i would appreciate it. The old clutch had three bolts and the new one has five bolts.
Old May 16, 2010 | 07:15 PM
panz4ever's Avatar
panz4ever
Not next to a manual but it adjusts the same as a 3 finger set up. Need to add slack the the handle cable, back off push rod
Distance from surface of the outer disc to inner edge of spring collar is 1-1/32". Adjust push rod so that distance from starter motor and clutch release arm is 3/8 - 5/8". Finally you need to take slack out of cable so that lever has about the width of a nickel slack in it.
Old May 22, 2010 | 10:19 AM
allegiance85
Stage II
worked great appreciate the help
Nick Sorgio
Shovelhead
Jan 30, 2017 07:37 AM
pops78
Nov 6, 2012 03:24 PM
gwolke
Shovelhead
Jun 18, 2012 05:17 PM
rickey67
Shovelhead
Nov 8, 2009 09:04 AM
djk
Dec 2, 2005 04:04 PM
