swingarm bearing pre-load
Old Jul 10, 2010 | 08:53 PM
81fxs's Avatar
81fxs
Stage IV
Default swingarm bearing pre-load
The manual suggests using a spring scale to pre-load the swing arm bearings between 1 - 2 lbs. Any ideas on a torque setting procedure instead? I'm sure i read a non scale method on this somewhere....just can't remember where.
Old Jul 12, 2010 | 05:55 AM
Shane Hutchins Sr.'s Avatar
Shane Hutchins Sr.
I'm pretty sure someone'll have an issue with this but, an old fart told me years ago (and bytheway he liked being called old fart) to snug the bolt till you have smooth easy movement (up and down w/no side to side) then continue to tighten untill you feel an ever so slight drag while activating the arm, then lock the nut with the lock washer. He was there for the process and showed me what he meant, it's not easy to describe but the diff. is barely noticeable. Seemed to work, changed out the rear wheel last year so ck'd the swing arm while up in the air. Still smooth and tight after 20,000 mi.
This method may not be for you but thought I'd throw it in anyway.
As for a tourqe spec. can't help but I'm sure someone can. I'd like to know too.
Shane
Old Jul 12, 2010 | 03:36 PM
flh80's Avatar
flh80
With everything off, I just tighten till you feel drag on moving it up and down. I never checked to see the torque, it would probably be only a few inch pounds. Maybe 5-10 at most, not much different than front Wheel bearings on an older car when you used to grease them.
Old Jul 13, 2010 | 12:40 AM
81fxs's Avatar
81fxs
Stage IV
Thanks for the responses.....I tightened it up fairly snug, then backed off and on a few times till the lock tab lined up with a flat side. Probably too tight ....I'd say closer to maybe 15 - 20 ft lbs. Taking it off required much more effort.
Old Jul 13, 2010 | 02:22 AM
Shane Hutchins Sr.
I think as long as the swingarm isn't binding up you'll be ok, couldn't tell you just how tight we ended up tightening mine but we had to reef down prettygood to get the snug fit. If you aren't getting any binding run with it.
Old Jan 15, 2011 | 01:16 PM
SkBuckwheat's Avatar
SkBuckwheat
Stage II
Has anyone fitted the swingarm with a grease fitting so removal is not required to grease your swingarm bearings?
Old Jan 15, 2011 | 07:21 PM
TwiZted Biker's Avatar
TwiZted Biker
Should have one , all the 4 speed shovel arms I've seen do .
There is no crush tube inside the swingarm so you have to pre load the bearings a bit . Put it together , run the bolt down till it's seated and see what kind of movement if any you get side to side and how free the up/down travel is . If loose go down 1/4 to 1/2 turns on the bolt till you get a slight drag on the up/down travel and lock it down . That's the way we did at the dealership in 1978 .
Ps if you have it apart use boat wheel bearing grease that nasty thick blue stuff , you can just about forget about it with that stuff , those bearings don't move 3/16" max .
Old Jan 16, 2011 | 02:19 AM
panz4ever's Avatar
panz4ever
If the swing arm is OEM, 58-61 swing arms did not have a zerc fitting. Wasn't used until 1962. There were 4 different swing arms used from 58 to 72. Apart from zirc fitting it came down to casting numbers and some extra reinforcement.
If you have one that is OEM it is either a Type 1 or Type 2 and bearing have to be repacked every 10K miles
Old Jan 16, 2011 | 03:09 AM
TwiZted Biker
Nice OEM details thanks I'll file that bit of info away had no idea they changed that rapidly , 95% of the stuff I see has been zerked already .
Old Mar 27, 2012 | 01:49 PM
Seiowa's Avatar
Seiowa
Stage I
Default Pfl parts
Take a look at this setup. Wish i wouldve found these sooner.
http://www.ttcycle.com/LifeTimeSwingArm.htm
