oil leaking
Old Jul 26, 2010 | 10:40 AM
bubba 40's Avatar
bubba 40
Default oil leaking
1980 fxe leaks oil when i crank it up heard iy might be check ball where is it located what do i do to fix it thanks
Old Jul 26, 2010 | 02:38 PM
tseek555's Avatar
tseek555
The check ball leak comes from sitting for a long time. Oil drains from the tank past the check ball over time and pukes about a cup or so of oil then it's done..
PM sent...
Old Jul 26, 2010 | 02:48 PM
TwiZted Biker's Avatar
TwiZted Biker
The check ball your looking for is in the oil pump , see the 2 caps on top of it ? You want the one in the middle of the pump . Go to the dealer or a decent shop and get a new spring and ball their cheap . Drain your oil or crimp off the feed line from the oil bag big mess if you don't pull the plug and gently pull the spring out , leave the ball for now . Find a roll punch or a piece of rod that just fit in hole about 4 " long and with a small hammer tap the top of that rod several times . What you have just done is made sure the check ball seat is good for the new one , over time grit and general wear wobbles it out a little and you puke at start up . Use a small magnet to pull the old ball out drop the new in do the oil and go , this at least slows the crap down if not fixing it 90% of the time .
Old Jul 27, 2010 | 07:53 PM
IronGear's Avatar
IronGear
Where does it leak from?
Old Jul 29, 2010 | 09:43 PM
flh80's Avatar
flh80
Use the old ball, tap it a couple times with a pin punch and hammer, then pull it out to replace. I've left the same one in after re seating it. You don't have to smash it. It may just have a chunk of dirt or something in the way causing it not to seat.
ronnie41653
Oct 23, 2013 08:48 AM
capecos
Oil Archive (no new posts)
Mar 30, 2009 08:09 AM
clever_21
Ironhead
Sep 22, 2006 06:26 AM
istoleurpen
Jun 8, 2006 08:40 AM
degr90
Shovelhead
Jan 16, 2006 06:06 AM
