solid tappets
Old Aug 17, 2010 | 03:44 PM
irondog's Avatar
irondog
Default solid tappets
I read a bunch of posts on converting to solids and it was a very straightforward job to do. i adjusted them just like my old ironhead, started the bike and it sounded great. after it warmed up the lifters became very noisy so i re adjusted them and again after the warm up they were again tapping away. shouldn't it be just the opposite? noisy cold and quieter when warmed up?
Old Aug 17, 2010 | 06:54 PM
sqdealgeorge's Avatar
sqdealgeorge
solids are not quiet get use to it What wt oil do you run ? If 50 wt try 60
Old Aug 18, 2010 | 01:57 AM
TwiZted Biker's Avatar
TwiZted Biker
What kind or brand did you get and did you use stock or the cheap fat alum. push rods ? Cam ? stock or ? makes a difference . Solids are going to talk period . You can knock down lot of it with the correct setup , the cheaper parts flex & bend , rub against rockerboxs and P tubes .
Old Aug 18, 2010 | 08:16 AM
irondog's Avatar
irondog
i bought a kit from JP with the chromoly push rods made in USA. stock cam. I understand they make noise but they make a lot of noise, more than my old ironhead. cold they are quiet, hot they are loud as hell!
Old Aug 18, 2010 | 09:39 AM
sqdealgeorge
If your running a stock cam (set up for hyd lifters ) That might give you more noise(has something to do with the cam ramp to pump up the hydraulic lifter ? ) When I adjust the pushrod at the lowest point of the cam (cold ) I adjust it to a tight spin with my fingers
Old Aug 18, 2010 | 09:45 AM
sqdealgeorge
By the way did you close off the oil feed holes in the lifter blocks ? These holes sent oil to the hydraulic units
Old Aug 18, 2010 | 09:57 AM
hobobiker's Avatar
hobobiker
+1 on both points. I adjust mine so they are a very tight turn by finger. Get used to adjusting them too, because they require more maintenance than the hydros. If you decide to change cams down the road, don't forget to check for endplay and space accordingly with an appropriate washer.
Hobo
Old Aug 18, 2010 | 12:01 PM
FLYING's Avatar
FLYING
I have solids with a C-Grind cam and as soon as Winter Time hits out they go !
The Evo Style are almost like a automotive type and Iam going to that conversion for
Hydraulics.I am just sick of the noise & adjusting ! I just do not see any advantage to keeping them.
Old Aug 18, 2010 | 12:05 PM
TwiZted Biker
All good info in here , the stock hyd. cam has an almost square lobe while the solid version is rounded so ya that's going to make more noise , the lifter slams pretty hard instead rolling over the lobes . While it works you didn't gain anything with that configuration , look into an cam for solids might save some headaches down the road . Good choice on the push rods I've got a shoebox full of tossed alum. ones , most bent .
A suggestion Flying , consider the Jims kits I've got several of those out in 88" & bigger motors trouble free oldest @ 12 yrs now . I've had 3 sets of the Velva Touch crap self destruct taking cams with them and they have zero customer service won't answer emails or a phone call so an heads up for what it's worth
Old Aug 18, 2010 | 05:32 PM
irondog's Avatar
irondog
I did go with the solids because of money issues, maybe when i have a few more bucks i will definitely go for the Jim's setup and for now i'll go for the tighter adjustments. one of the old hydraulics would bleed down or stick every once and a while so i took the less expensive route. thanks for the all the help. Ride On!
