Andrews AB question
Old Sep 7, 2010 | 11:50 AM
olfart's Avatar
olfart
Default Andrews AB question
Can an Andrews AB grind camshaft be run successfully with solid lifters?
I've seen references like this here and there: "you can run solids on a hydraulic cam, but you don't run hydraulics on a solid cam."
Wondering if that's a true "rule of thumb", or BS.
I got a new Andrews AB in my hand even as I type. Also have solid conversions in the bike. No way I can afford to switch to a hydraulic set up. So hoping I can run this cam.
Thanks
Old Sep 8, 2010 | 02:25 AM
TwiZted Biker's Avatar
TwiZted Biker
Thats true to a point for shovels meaning as long as it's a mild cam to start with , there,s a boatload of math to explain why I'm not getting into . The " AB " will work ok but your going to disappointed running it , if the gear on it is timed correctly it doesn't come on till 3500+ RPM or around 60+mph . Unless your a stop light hot rodder you will not get much use out of that cam .
Also you may have to shave the insides of your rocker box's a bit to get clearance so the spring collars don't hit on some yrs . Been a while since I,ve done any Andrews cams so do some checking around on that .
http://www.nightrider.com/biketech/
Good Luck
Old Sep 8, 2010 | 07:12 AM
prodrag1320's Avatar
prodrag1320
Any cam can be used with solids,but you cant run any(big,aggressive cams) with hyd. Lifters
Old Sep 8, 2010 | 07:37 AM
olfart's Avatar
olfart
Hey TwiZ, you said:
"going to disappointed running it , if the gear on it is timed correctly it doesn't come on till 3500+"
Your right. I would be disapointed with that, and for that reason.
Does the Andrews A-grind come on any lower?
Old Sep 8, 2010 | 03:58 PM
TwiZted Biker
How do want the bike to run ? You a hot rodder or is it your daily driver needing a little more omph ? You can get better low end & mid range or better high end , can't do both without engine work . I don't like Andrews cams for shovels they all are mid range and up performers 2800rpm and up your flat under 45mph . Best ones I've found are the VThunder series by Competition cams their designed for hyd. lifters . I've tried them all and the VT cams work best from 1000rpm on . Down side is only the first step up is bolt in the really good cams take valve spring kits . Check this link my help a bit .
Shovelhead Camshafts
Old Sep 8, 2010 | 04:44 PM
flh80's Avatar
flh80
Thanks
I believe it's the other way around, Hydraulic lobes are ground with more of a hump to compensate, solids are a smoother lift and drop. So a solid tends to jump on a Hydro cam, a hyd lifter would follow a solid lobe but looses response.
Eastcoast Jim
Engine Mechanical Topics
Sep 13, 2016 08:41 AM
harleycharlie1992
May 4, 2013 10:34 AM
t150vej
EVO
Dec 21, 2008 01:45 PM
geargrinder
Exhaust System Topics
Jan 21, 2008 12:12 PM
Timboto
Shovelhead
Sep 30, 2007 09:33 AM
