Brake system & proper fluid
Old Jan 22, 2011 | 06:31 AM
IronGear's Avatar
IronGear
If by everyone, you mean everyone one but me, then that makes sense.
And if you mean "nobodys an expert", except me, then that might also make sense.
I do not need to do any research, and I am an expert.
Others are expert at other things, I am expert at this.
Old Jan 22, 2011 | 09:43 AM
Steelhammer's Avatar
Steelhammer
So it has been written
Old Jan 23, 2011 | 12:24 AM
IronGear's Avatar
IronGear
There was nothing written about my being hailed a hero.
If you feel inadequate, improve yourself, as opposed to trying to denigrate others.
It works way better.
Old Jan 23, 2011 | 12:46 PM
Steelhammer
I don't think anyone has been hailed a hero, probably just your cocky attitude. End of conversation also, I know where you record stands on this forum as being a "Know it All" and personal attacks on who you think doesn't know as much as you think you do. I've worked with people like you for 40 years and know exactly how to deal with them.
Old Jan 23, 2011 | 09:21 PM
V_twins's Avatar
V_twins
Originally Posted by j1mmy
dot 3 and 4 are mineral oil,they absorb water and boil when brakes get hot.4 has a higher boil point then 3.dot 5 is silicone it doesn't absorb water.nothing different in systems,you can use any of the three but you cant mix them..it turns to Jello and plugs everything up..the labels on the parts are just to try to idiot proof everything.makes it more confusing on custom work
that's right... but also remember... DOT5 is NOT the same asl DOT5.1...
some shops try to sell it as the same stuff.
Usually older HDs use DOT5... I do not about new ones since I do not have any.
Old Jan 24, 2011 | 03:51 AM
IronGear's Avatar
IronGear
Find a post where I said I know it all, and find a post where I addressed the person, and not the issue.
Find where I said, "you are an idiot because you do not know".
You never will.
You have attacked me personally, whereas I have, as always, stayed away from that.
I do know. That is obvious.
So quit crying about it.
People like to say, "well, we are all learning.....", so as to excuse their ignorance.
I am not learning. I have experience and knowledge.
The ones who mock me are the ones who pretend to know, and then are exposed as not really knowing at all.
THAT IS YOU.
Now if I made a negative comment about as a result of that fact, you would be right.
BUT I NEVER DO.
That's because.......
I am not like you.
Remember.....
It is not mandatory for a mechanic to be stupid.
It is merely common.
I am the exception.
Old Jan 24, 2011 | 05:25 PM
Steelhammer
Originally Posted by HGM
Yea, its so clear that you even have a suggestion.. Nothin like a know it all.. I'll be the first to admit I dont and am always open for advice.. On the surface, you may be correct, but in my situation, I've learned that the traditional thinking has not identified the cause, not just by me but many other guys who know much more about EVO's than I. The bypass will be rated for the micron rating, with a 5m filter, high volume could trigger the bypass on a system designed to use a 30m filter(less restrictive)... The bypass may not provide the volume needed to feed the system...The EVO is a low pressure system, but the volume must be there... With my 20+ years of wrenching, I've learned a couple of things. Nothing is impossible and you can never say the words cant and wont. And dont be a ******** before knowing all the details..
(Here's one instance of a reply back), you have evidently taken a class in creative writing also pal, your know it all attitude proceeds you, and you may well be an expert, but trying to make everyone else look like they are a dumbass just doesn't cut the mustard. Grow up
Old Jan 24, 2011 | 10:33 PM
IronGear's Avatar
IronGear
I accept your concession.
I really do not need classes in any form of writing.
Old Jan 24, 2011 | 10:38 PM
IronGear's Avatar
IronGear
Why would I need to do that?
I just state the facts regarding motorcycles.
You focus on trying to get out of the hole you have dug for yourself, ........ by digging deeper.
If you feel silly when someone posts correct info, contradicting what you have stated, then look to yourself.
Refrain from posting opinion as fact.
This is a brake thread. People could literally be killed if they followed some of the garbage posted.
If your sensibilities have been offended, then at least your life has been preserved.
You should be grateful. But no, you rave on and on instead.
Old Jan 24, 2011 | 11:19 PM
Steelhammer
Like I said, your rude, arrogant, ***** all over this forum, case closed. You forgot to read the into the real point here. Have a great day!
