Smoking
Old Mar 27, 2011 | 02:44 PM
clove07's Avatar
clove07
Default Smoking
Smoking My 80 FXE smokes when i let off the throttle. Still runs good no smoke at idle just when i let off the throttle. Last summer new valve job, Pistons, rings, white smoke. and is using oil not much.
Is it valves
piston rings
Any help will be greatly appreciated
Old Mar 30, 2011 | 12:18 PM
R-Jay's Avatar
R-Jay
Sounds like valve guides. Did you replace the valves and guides or just have the valves and seats ground? If I was going to do a valve job, I would also pull the jugs and check pistons, cylinders for wear. If needed to do, it makes more sense to take it apart once and cover all the bases.
Old Mar 31, 2011 | 10:30 PM
TCMAN's Avatar
TCMAN
Exactly what R-Jay said!
fido1
Engine Mechanical Topics
Mar 26, 2014 05:30 AM
Rocker_C
Pacific
Mar 6, 2012 12:11 AM
DeluxeCruiser
The General Motorcycle Forum
Nov 17, 2009 11:35 AM
