transmission trouble
Old Apr 19, 2011 | 04:39 PM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by 46u
I have worked on not only transmissions like this but many old Harley s. LOL
Thats sort of my gig , all I do are shovels and the occasional pan . I see them after every other shop in a 100 mi. radius has turned them down and they are always a day from catastrophic failure on several things . Then add most are broke and don't want or can't spend a dime . At this point bro with what you've found I'd be leaning to find another trans , at least a box with gearing intact . Going to be cheaper in the long run than dicking with welding and machine work on a trashed case . Seen them on egay and I would hunt craigs list in your area if you don't have a line of buddies with junk boxes to dig in .
Try Jehir if you go a new case they have them for $170 , I've done a few with their cases and like them better the STD or a couple others that were way more money . I'm not a big fan of CCI Rev Tech stuff but they have complete gear sets going around $ 400 give or take on egay all the time . Good luck man I feel you .
After dropping the money on that fancy shift fork tool think I used it once and ended up cutting the complete dome off a jockey shift cover and using that instead .
YeOldeStonecat
Shovelhead
21
Sep 9, 2015 05:39 AM
billytwobags
Jul 11, 2013 11:38 AM
grady
May 7, 2013 10:58 AM
prplglide
Mar 14, 2013 12:46 AM
CTCNC
Aug 22, 2008 03:07 PM
