1971 fx
Old Jul 13, 2011 | 09:57 PM
john2189's Avatar
john2189
Stage II
Default 1971 fx
I had a S&S 93 cubic inch Hot Set-Up kit put in my bike last winter and since I've got it back the motor has maybe had an hour of run time on it. My problem is that I can't get the bike to start, it sat all winter and most of spring and i rode it a few times on a gravel road without the derby cover on the Dyna S ignition, and I was wondering if maybe the little bit of dust from riding and the dust and moisture from sitting could cause my bike not to kick over. By the way the bike is kick start only so it's sort of a pain to have to kick it over and over again. If anyone has any info or some advice I would appreciate it, thanks.
Old Jul 13, 2011 | 11:11 PM
TwiZted Biker's Avatar
TwiZted Biker
Getting any spark at all ? try retarding the timing a bit and get a decent supply of new plugs till you get some more break in miles on her and find the sweet spot for timing , I'm running the same engine and early on they can be a bitch on plugs till broken in .
Old Jul 14, 2011 | 07:43 PM
stinkity stoink's Avatar
stinkity stoink
6th Gear
if you have spark than it is more likely fuel. If the bike ran fine I imagine the timing isn't off to much. Maybe you have to prime the motor with fuel for a cold start. My 80" shovel is kick only . When I start it cold I give it 5 kicks (just turning the motor over) with choke on and ignition off. On kick # 6 I turn on the ignition and she fires up .
Old Jul 15, 2011 | 07:12 AM
CDN. RG's Avatar
CDN. RG
if solid lifters,most likely need to be adjusted.
yorgle7
Aug 6, 2016 12:02 PM
Furrmyster
Engine Mechanical Topics
Dec 3, 2015 05:37 AM
leapingknome
Shovelhead
Nov 26, 2012 12:24 PM
dkaat
Shovelhead
Sep 4, 2012 03:12 AM
shireydj
Shovelhead
Jul 19, 2008 07:51 AM
