Used triple Tree issue
Old Feb 6, 2012 | 10:20 AM
Edward Brown's Avatar
Edward Brown
Default Used triple Tree issue
Hi all, I'll try to keep this brief and to the point. I have this 77 FXE that I just got a used set of triple trees for so I ripped out the old stock originals to find that the stem is a larger size ? tell me if I am wrong but aren’t all stems the same size and all I should need to do is by the same bearings and race if not what would I need to do to fix this issue and use the newer triples.
Old Feb 6, 2012 | 12:00 PM
sqdealgeorge's Avatar
sqdealgeorge
Default triple tree stems
You might have gotton a set of trees off an old sportster they ran from 7/8 in to 15/16 in(1978-81) and finally to a 1 in after 1981
Old Feb 6, 2012 | 12:29 PM
Edward Brown
What size stem is a 77 FXE ?
Old Feb 6, 2012 | 02:05 PM
sqdealgeorge
Default stem size
I remember it being 1 in
Old Feb 6, 2012 | 02:40 PM
TwiZted Biker's Avatar
TwiZted Biker
Stock 70's fl or fx is 1" and if the one you got is bigger somebody sold you a honda tree , saw a lot of that go round at swap meets yrs ago .
Old Feb 7, 2012 | 06:28 AM
Edward Brown
No it is smaller can a smaller id bearing be found ?
Old Feb 7, 2012 | 10:46 AM
TwiZted Biker
If it's smaller you got a sporty tree , I heard there was a cone bearing conversion for those but I have no idea if they are the same or not , I don't do anything sportster might check in the that forum ?
mcgainey_86
May 3, 2016 04:26 AM
mitchxc700
Shovelhead
Jul 10, 2013 07:57 AM
YoungSport
Dec 12, 2011 11:35 PM
mikemc
Jun 1, 2010 11:15 PM
streetbobkid
Feb 18, 2010 07:08 PM
