81 FXS Lowrider - dragging start
Old Jul 15, 2012 | 04:03 PM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by Jonathon Beaudin
Hey u said "measure" my cables... I just got random lengths. They are all longer than the originals... Would that cause the problem???
Not really unless they get into the feet long instead of inch's , just a cost thing that's all .
Old Jul 29, 2012 | 09:35 AM
aces101's Avatar
aces101
6th Gear
Sounds like the same issue I had on my stock 80ci. Turned out to be a crappy (new) ACCELL soenoid. The contact washer inside the solenoid is made of some kind of material only the Chinese government knows of. I replaced it with a copper washer and now it cranks like new. If you're smoking cables and the starter is struggling check that washer out and see if its burned and trying to weld itself onto the copper terminal contacts. If so replace it with a quality copper one, it's a cheap fix if that turns out to be your problem.
Old Aug 2, 2012 | 01:17 PM
Jonathon Beaudin's Avatar
Jonathon Beaudin
Wow good idea, I did notice how crappy that washer seemed to be for that much power to go through. Thanx
Old Aug 4, 2012 | 07:45 PM
Jonathon Beaudin
Well for one I can't find a proper copper washer anywhere... :0(. I have used a screwdriver to jump the solenoid, and it doesn't change the pace of the cranking. I pulled the All ***** starter I put in and one of the wires to the field coils on one side was broken. I'm saudering it together now, and I'll reinstall it. Brand new starter... I'll let u know if that fixes it
Old Aug 5, 2012 | 02:21 AM
Jonathon Beaudin
Ya that was it! Pfffft!
Cranking good now
Jonathon Beaudin
Cranking good now
CH53A/D CREW CHIEF
May 11, 2019 02:17 PM
Rijan
Apr 29, 2019 04:57 AM
user 6485939
May 26, 2018 01:52 PM
ozzie65
EVO
Apr 6, 2009 03:22 PM
