83 Harley Davidson Lowrider 4 speed Belt Motorcycle
Howdy guys.. I need some help I have the book Im just not seeing it.. IM trying to remove Primary Case that has the belt in it.. My main belt that leads to the Rear tire has broken and I have to take off the whole case to get to it.. How do I lock the engine to I Can remove the compression belt since I cant get the engine to lock
Are you using a factory manual or a Clymers? The factory manual is very clear on how to replace the rear belt. The front pulley and clutch, clutch basket and hub have to come out. The starter has to be removed, and then the inner primary comes off. Then you remove the rear fork (swingarm), feed the new belt in and reverse the process. This is the short story with a lot of details left out. Most of us use a impact to remove the front pulley nut, and the nut that holds the clutch hub is a reverse thread (turns right to come off). Did that help?
Try shovelhead.usa forum. That's how I learned. You can use 50' of 1/4" nylon rope stuffed in a cylinder to prevent the motor from turning. Make sure to leave a foot outside...duh.
I would avoid using an impact wrench because of hearing too many tales of damage to the crank and wheels assembly.
For my pans and shovel I have always used an impact to remove the primary and motor nuts (remember clutch nut is counter). Can say I have never seen any proof of the "damaged crank and wheel assembly"....not disavowing it, just saying that in my time on/around HDs I have never seen it. Outside of that you need to use some type of bar between the primay and drive sprocket to lock the two and a breaker bar.
