Speedometer ratio question
Old Nov 3, 2012 | 08:55 AM
WoodrowWillson's Avatar
WoodrowWillson
Default Speedometer ratio question
I have a 74 shovel with a ratchet top 4 speed. The old speedo was a 1:1 but it had the stock 16" tires. I am putting a 21" on the front and 18" on the back anyone have an idea of what ratio I need?
Thanks
Old Nov 3, 2012 | 02:39 PM
Tom84FXST's Avatar
Tom84FXST
Thanks
If I understand you correctly, you are diving the speedo off the trans. Only the back tire will affect it...and there is very little difference in the diameter of a 16 and 18 because the 18 is low profile...so it will be fine.
http://www.steelthundercc.com/tiresizes.html
Old Nov 3, 2012 | 06:01 PM
TwiZted Biker's Avatar
TwiZted Biker
Leave it alone you'll be fine as is stock speedo's on the old bikes are off 5mph or more anyway , changing it involves a tranny tear down .
Old Nov 4, 2012 | 06:56 AM
AlCherry's Avatar
AlCherry
I've always beem told the front speedo drive was a 2:1 and the tranny drive was a 1:1. Generally, the 16, 18 and 19 inch tires are all the same diameter, +/-. The difference is not enough to affect the speedo, as Twisted said, they are off 5 mph or so anyway.
Old Nov 4, 2012 | 10:46 AM
TwiZted Biker
Al they had both ratio's in trannies , you could tell by the tooth count on the drive one had big teeth, 11 count =1:1 and the other was fine toothed 23 count =2:1 and for the life of me I can't remember which was which for what years they mixed & matched all the way to 1980 if I remember right .
The front wheel system has 3 ratios available just to screw with things a bit more you have 1:1 , 2:1 and they added a goofy 2260:60 drive for the evo models & up .
Old Nov 4, 2012 | 05:18 PM
AlCherry's Avatar
AlCherry
At my age, I get confused about all of that. I didn't run a speedo for years because everytime I hooked it up, I got a damn ticket. Though I got a ticket in Oklahoma once cause the speedo wasn't hooked up. The Highway Patrol drove around me and didn't see a cable going to the front wheel. He backed off, pulled me over and I didn't have one going to the tranny. He knew his Harleys. In Oklahoma, motorcycles have to have a speedo. Whoda thunk..........
Old Nov 6, 2012 | 10:31 PM
TwiZted Biker
2 guesses how I got the education on all that crap ................
Old Nov 7, 2012 | 10:16 AM
panz4ever's Avatar
panz4ever
Twizted...the 2260 speedo is also used on my 84. Not sure what year, how far back it goes though, but it was a pain to replace. No one fixes them and trying to keep OEM/NOS took some time.
Ran with Tawain Ted $hit (went through two iin less than a year and 6K because they kept breaking) and finally found an OEM outta a HD shop in New York
Old Nov 7, 2012 | 02:22 PM
TwiZted Biker
Thanks for the info I didn't know they where in use that far back . You know the only reason they went that way was it's all imported now and they are dancing to make MPH speedo's work with KPH hardware .
Dustinleras
Jun 9, 2013 04:49 PM
dub976
Aug 6, 2012 12:24 PM
CycleNaz
Panhead
Mar 31, 2012 09:56 PM
Anezangl
Mar 27, 2011 02:15 PM
legman55
Feb 12, 2008 08:40 PM
