Shovelhead bagger project update
Old Mar 11, 2013 | 08:49 PM
shovelhead FXEF's Avatar
shovelhead FXEF
Originally Posted by SURFOR Chop
Got a photo of the saddlebag brackets mocked up on the frame ...?
Cycle Visions softail mount on shovelhead swing arm frame. Mounts to top peg hole and to strut
Old Mar 11, 2013 | 09:55 PM
SURFOR Chop's Avatar
SURFOR Chop
Nice ... are the bags going to clear the shock ...?
I'm in the process of getting the Dyna BaggerTail setup ... there are special bags CV7410 / CV7411 that have a recess at the front inner corner to clear the shocks ...
I've got a set on order and expect them in this week ...
BTW ... great project ...
R/
'Chop
Old Mar 13, 2013 | 06:33 PM
shovelhead FXEF
R/
'Chop
plenty of room to clear shock
Old Mar 18, 2013 | 09:26 PM
shovelhead FXEF
Painted parts came back today. Front fender is installed. Painter Craig Smith did an awesome job. More to follow this weekend
Old Mar 20, 2013 | 07:34 PM
shovelhead FXEF
Made a little progress today. Front end is complete
Old Mar 20, 2013 | 07:44 PM
Tom84FXST's Avatar
Tom84FXST
Looking good...I bet that will rock!
Old Mar 20, 2013 | 08:08 PM
shovelhead FXEF
Thanks Tom. It rocks pretty good. Hoping to get the tanks on tomorrow. Then move to the back for the bulk of the final build. Wanting to run late model slip ons, so the exhaust is becoming quite a challenge
Old Mar 23, 2013 | 06:27 PM
shovelhead FXEF
Made good progress today. Moving onto installing bag extensions and exhaust. Bags fit real nice!!
Old Mar 23, 2013 | 07:49 PM
Uncle Larry's Avatar
Uncle Larry
That is definitely a clean look from the rear ... You've done a nice job ... I like that you've retained the "banana caliper" ... the Pyramid Adjusters for the rear axle are the same ones that I have on mine ... You'll have a scooter to be proud of .. and you can say that you've done all the work yourself ... and that's the best part Brother.
Old Mar 24, 2013 | 07:51 AM
TwiZted Biker's Avatar
TwiZted Biker
I took that idea few steps further when I started screwing around changing pulley sizes and ratios to find the sweet spot for my rig . Using a 121 toothe belt and it took a bit of modifying to get enough travel in my swing arm . Had to elongate the slots 3/4" of an inch more and made up some beefy adjusters to help retain strength when I opened the slot up , had a bigger gap then my ex wife only this one I could something about it
Big slot now , ( think about my ex every time a I see a big gap ) can't have this as the swingarm will tweak
My solution after a half bottle of Jack and digging around my stash boxes , good excuse to play with new mini mill / lathe I picked up .
