oil leak question
Old Apr 1, 2013 | 07:14 PM
tennesseeguy's Avatar
tennesseeguy
Default oil leak question
I'm new to the Shovel engine world and working through a few little things with the '82 I just got. I have an oil leak on what the manual calls the 'tappet oil screen plug' It looks like a pinhole and it's off center so sure it isn't supposed to be there. It is on top of the gear case and takes a 1/4 allen wrench to remove it. It is seeping oil pretty bad..too bad to ride the bike.
It's item #1 in the pic . I am wondering where I can buy the plug at? I have no idea the thread pitch to it??
Thanks for any pointers. I know its minor but Im still learning..
Old Apr 1, 2013 | 07:25 PM
V_twins's Avatar
V_twins
you probbaly just need a new washer for it
Old Apr 1, 2013 | 07:36 PM
Tom84FXST's Avatar
Tom84FXST
http://www.jpcycles.com/search/searc...text=0&Ntk=All
Old Apr 1, 2013 | 08:10 PM
tennesseeguy
thanks guys, I had no idea JP carried things for this old a bike..makes mental note to search better before posting....the leak is through a pinhole in the plug so pretty sure it isnt the gasket or O ring. It may serve as a check valve or relief valve? It may need the vent? I'm learning lol
thanks
Old Apr 10, 2013 | 12:31 PM
flh80's Avatar
flh80
thanks
No there isn't supposed to be any hole in it. There should a brass washer on it also to seal. - http://www.ebay.com/itm/TAPPET-SCREE...846b18&vxp=mtr
Old Apr 10, 2013 | 02:57 PM
tennesseeguy
I got one from JP Cycles..talked to a local indy and he said in his 26 years working on bikes he had never seen one develop a hole in it. I guess my luck LOL..anyways, it's fixed now and just the normal seepings and things to try and make a little better now.
Old Apr 10, 2013 | 11:31 PM
TwiZted Biker's Avatar
TwiZted Biker
Seen some of the cheap import allen caps for those develop leaks before . Real chessy cheaply made crap or somebody was going to make a oil fitting and blew it had one come through here still had the broken drill bit in it .
jjpish
Dec 28, 2020 12:12 PM
hotrod351
EVO
Sep 23, 2013 07:38 PM
Bugspit
Jul 22, 2013 07:29 PM
hoppypy50680
Sep 9, 2007 01:45 AM
Oakster
Oil Archive (no new posts)
Jul 11, 2007 07:01 PM
