shovel problems
Old Jul 29, 2013 | 09:14 PM
bonesmutley's Avatar
bonesmutley
Okay I've had the battery checked and refilled with acid, put it on and got a running read in the 12s so I guess my bike isn't charging. What would be the next thing you'd recommend checking?
Also if I continue to ride it shouldn't it drop below 12 as it dies or will it always read there.
Thanks
Thanks
Old Jul 29, 2013 | 10:34 PM
bonesmutley
I'm check the wires tomorrow for a short and grounding, then Ill. Heck the stator and on from there.
Any tips?
Thanks
Old Jul 29, 2013 | 11:22 PM
bonesmutley
A quick search answered everything I could need to know.
Great site!!!!
Old Jul 30, 2013 | 07:35 PM
bonesmutley
Turned out to be a bad positive wire. Now it reads 13.6 and 14s when reved.
Old Jul 30, 2013 | 07:59 PM
scaldwellk's Avatar
scaldwellk
Good to hear and glad you found it.
Old Jul 31, 2013 | 08:51 PM
bonesmutley
it's reading 14.20 with a small amount of speed but dips to 11 and other random lower numbers when running. Is that a problem or just the old shaky shovel.
Other numbers anywhere from 11 to 8.
Thanks in advance.
Ian
Old Aug 10, 2013 | 02:58 AM
Jimbo Slice's Avatar
Jimbo Slice
should be close to 14 all the time you may want to check the stator and if its pushing the correct amount it is probably your voltage regulator. FYI those usually go out in pairs. But since it goes to up to 14 i would guess the VR. Also you may want to check for the proper gauge of wire from the VR to the battery.
Old Aug 12, 2013 | 11:43 AM
Oldskewl's Avatar
Oldskewl
Thanks in advance.
Ian
That's about where it is gonna be. These old shovels don't put out 14 when it's at idle. As soon as you rev it up a little jumps to to 14 right... if so you are golden.
One thing to note, i took dense foam and wrapped my battery housing and stuffed every loose inch of my oil bag to keep the battery from shaking around. It actually made the batteries last another 6 months. regardless, batteries don't seem to last much longer than a couple years in these bikes. The vibration and acid loss kills them off quickly.
Good luck
Old Aug 15, 2013 | 02:53 PM
bonesmutley
Thanks I'm gonna stuff it with foam.
Old Aug 16, 2013 | 01:24 PM
i Confederate i's Avatar
i Confederate i
As far as I know, there were never plugs on the right side on a stock shovel. Its all aftermarket in an attempt to clear the cylinders better. Depending on where they got the kit to punch the new plug holes would determine the proper plug gap and number.
