Cats Eye Dash Fitment
Old Nov 12, 2013 | 07:53 AM
Bohemian's Avatar
Bohemian
Default Cats Eye Dash Fitment
Bike is 1980 FXWG OEM Frame, Engine, Tranny, can't speak to anything else...
So I have two cats eye dash kits laying around that I am trying to make one or a combination of the two work on my fxwg fatbob tanks ...
looks like I absolutely have to use the base that has the extension tab on it to mount to the big tank mount on top of the frame...
if i use the flat base i would have to cob something to go around the tank crossover in the way...
i don't see any difference between the two dash covers...
holes appear to be in same place and look like they will work with either base...
my current dilemma is the rear of the dash cover sits about 1/2" above the tanks when everything is mounted up...
anybody know what the issue could be?
am i missing something obvious?
thanks in advance.
Old Nov 12, 2013 | 02:34 PM
Oldskewl's Avatar
Oldskewl
Last time i did a catseye dash I had to trim it to fit my tank.
Using a dremel tool and some tape to protect it.
Old Nov 12, 2013 | 08:50 PM
Bohemian's Avatar
Bohemian
don't know what I would trim, cut since everything fits, bolts together without modification; I just have this 1/2" gap between the tanks and the bottom of the rear half of the cateye dash cover itself...
I was under the impression there were only two styles of these ... OEM's for the older bikes and the new style for like 66-84 shovelheads with fatbobs...
the base seems fine, so I am wondering if there is some other cateye dash cover i need? or different tanks? or?
Old Nov 12, 2013 | 09:57 PM
panz4ever's Avatar
panz4ever
Guess my first question is if your gas tanks are OEM or aftermarket. Sounds like the dash plate assemblies are definitely not OEM.
So just confirm...there are no shims under the back of the baseplate.
The steel cats eye dash was replaced in 1948 withe another steel assembly; not sure when they switched to the cast covers.
Can you lift the tanks to meet/take up the gap. It will not happen with the tank mount holes but you might get away with hogging out the rear frame to tank holes
If you have C h i n c k $****…dash plate assembly and/or tanks, the only way you will make it work is to use a dremel tool to form the dash cover to your tanks. Just make sure your tanks are level before you start masking, scribing and grinding
Old Nov 12, 2013 | 10:39 PM
TwiZted Biker's Avatar
TwiZted Biker
Aftermarket dash kits can be all over the place for fitment and it gets even more interesting with non OEM tanks , sounds like you've got a mix of backplates . With the import cat's eyes I've had to space the front & rear mounts to the frame with very different thickness shims to fit and on the flip side had to cut & re-weld another to lower it along with bending & flexing the mount plate and where the speedo sits to get everything aligned & looking proper . Welcome to Taiwan Teds world of custom fit .
Old Nov 13, 2013 | 07:11 PM
Bohemian's Avatar
Bohemian
I have 2 complete kits ...
believe it or not my bases are deeply stamped V-Twin U.S.A. ...
maybe they pre-date Tedd Cycle farming out all this kind of stuff to china/tawain?
had them for a while, swap meet stuff...
no markings on dash covers...
only difference appears to be base plates...
one works perfect and the other is a mile off, clearly made for fatbobs without a crossover hose where mine is...
I have no idea if my tanks are O.E.M. or not...
No doubt, frame, cases, tranny are OEM H-D & the cases & frame numbers match the title...
I don't think I need to remove any material from anything IMHO, as far as I can tell the radius of my tank and my dash cover don't jive... pretty much from right behind the ignition switch back...
when the base & cover are all lined up and bolted down there is about a 1/2" gap between the back couple of inches of the dash cover & the tanks ...
it seems like I need a different set of fatbobs but I am not clear if there is a specific set these dash's were designed for or not...
about all I can find is early model oem style or late models for shovelhead fatbobs...
I really like the way these dashes look, just wish was not such a PITA ...
Old Nov 18, 2013 | 08:02 PM
Grinder Bill's Avatar
Grinder Bill
The catseye dash was never intended for 5 gallon fatbobs, so the curvature and mounts are all off. I ended up custom fitting the whole works.
Old Nov 18, 2013 | 08:37 PM
Bohemian's Avatar
Bohemian
looks awesome, you did a smoking job...
Old Nov 18, 2013 | 09:31 PM
Grinder Bill
Thanks bud. You can see how the dash mounting plate was modified to fit the tanks; start there and work out. The front cover got cut off and a new one with the proper radius was bent up and welded to the dash panel.
If you don't have a small mig, now is a good time to justify buying one...
Lindosan
Apr 8, 2016 01:46 AM
McCutcheon44
Shovelhead
Apr 2, 2016 10:08 PM
8ntsane
Jun 1, 2014 07:59 PM
cherrick
Sep 17, 2011 08:24 AM
blackmopar
Apr 13, 2008 10:16 PM
