Rocker arm shimming
Old Mar 13, 2007 | 02:13 PM
onewayphil's Avatar
onewayphil
Default Rocker arm shimming
BEWARE!!!! I just got a rude awakening after installing those RAMJETT rocker arm shim kits on my shovel. After reading some posts on another website that said they were garbage, I decided to take them out after just 2or3 heat cycles and apx. 10 miles on the new motor.What I found was one of them was already broken in three pieces! I had to remove the back head and luckily I found all the pieces in the rocker arm box before the things had busted up and went down the oil drain. If YOU are running them in your shovel please take them out NOW. You'll be glad you did!!!
Old Mar 13, 2007 | 08:12 PM
pococj's Avatar
pococj
Default RE: Rocker arm shimming
Guess the quality has gone down in the years since I ran 'em. I hada set in my Shovel back in the early '80s (???) and ran aver 100,000 miles with them. Shame 'cause they make getting rid of the rocker clatter easy.
Old Jun 8, 2007 | 06:08 PM
crampfan's Avatar
crampfan
I found that if the clearances are close to spec. the washers will break (too tight). it's not that hard to shim them the right way. the nylon seals in the kit are the bomb though.
1984 flhs
Shovelhead
24
Oct 30, 2018 09:00 PM
89FLHTC
EVO
13
May 19, 2016 06:04 PM
Cookiejar
Exhaust System Topics
Sep 4, 2012 08:42 PM
tricone
Shovelhead
Aug 9, 2007 12:32 AM
joe
Apr 20, 2006 09:44 AM
