Four Speed False Neutral
Old Dec 3, 2013 | 04:18 PM
vman883's Avatar
vman883
Stage I
Default Four Speed False Neutral
Hi all. This is my first post, but I've been a long time reader here.
I have a 1980 FXWG. Last year, rebuilt the transmission with all new Andrews gears, new pawl springs, bushings, etc.
A few weeks ago, I upgraded my clutch to a Rivera Primo setup. After the new clutch, I started having an odd issue. Transmission shifts smooth as can be. BUT, every fifth or sixth time when I downshift from fourth to third, I hit a false neutral. It seems like it overshifts and the position of the rotary plate is past third gear, but not yet in second.
The only way to get back in sync is to downshift again until it hits second, then upshift to third.
When I rebuilt the trans, all the springs were replaced and there were no rough edges on the shift plate. This suddenly appeared with the install of the new clutch. Any ideas other than pulling the lid. It ran great until the new clutch.
Thnaks!
Old Dec 3, 2013 | 06:00 PM
johnjzjz's Avatar
johnjzjz
i seen one when using the impact on the clutch hub nut it disturbed ( jumped out ) the open end snap ring clip for 3rd gear i dont know how you tightened the hub nut but that would be my guess -- we now only use the spiral lock type
you did not say the shifter is different so the downshift spring should be ok BUT < always a BUT -- the detent screw holding the 2 pauls and springs could have backed off < the small screw on the bottom of the shift selector did you put blue lock tight on it ???? -- johnjzjz
Fblo1690
EVO
14
Oct 12, 2017 11:34 AM
rainsong
EVO
Oct 2, 2017 12:33 PM
cmosentine
Jul 1, 2013 08:24 PM
northeastconfederate
Jan 31, 2013 10:26 AM
lstcause616
Dec 27, 2010 10:51 PM
