S&S E on a 76 FXE
Old Jan 3, 2014 | 03:49 AM
biginchhustler's Avatar
biginchhustler
lets see if this pic works ---
THIS IS WHAT YOU WANT -- EXCELLENT POWER LOW/MID/TOP -- A SOUND LIKE NO OTHER..
Old Jan 3, 2014 | 03:52 AM
biginchhustler
A FEW TOOLS-- SOME FRIENDS AND ,,,AND,,AND,,,, LOL
Old Jan 3, 2014 | 03:57 AM
Stiggy's Avatar
Stiggy
Start around 28 & 68
Old Jan 3, 2014 | 10:28 AM
biginchhustler
see the pipes STIGGY has? those work and look good
Old Jan 3, 2014 | 05:20 PM
Stiggy's Avatar
Stiggy
Yes, they do work and sound nice. Thanks biginch!
Old Jan 3, 2014 | 05:26 PM
biginchhustler
I made mine-- that big *** collector behind the merge collector is off of a 1981 Kawasaki jet ski -- it has a s/s funnel attached by springs to control the back pressure
Old Jan 3, 2014 | 05:53 PM
j1mmy's Avatar
j1mmy
a shovelhead is not a tuner, its really not that complicated.. run drag pipes,super E carb, you don't need anything else fancy. you might lose a couple HP here or there, but does it really matter. knucks,pans, and shovels, not to mention sportys have been running that way for a lonnngg time. as far as i know, you cant order a carb with a certain jet size. it comes with the best jet to get started. the bike will run, idle/mid will probably be fine. if it needs it, you can order jets a size or two up and down and change them as needed. S&S carbs usally do have a little bit of a dead spot at mid range. if it bothers you, they sell a thunderjet that makes midrange adjustable.
Old Jan 3, 2014 | 07:13 PM
johnjzjz's Avatar
johnjzjz
a new S&S carb comes with up and down jetting for each motor its boxed for, so you have adjustability just for that reason - the directions inside the new unit will guide you to just about any combo a street bike has < they have done it all hundreds of times just follow S&S directions and your done - johnjzjz
Old Jan 3, 2014 | 07:30 PM
ROTTEN ROB's Avatar
ROTTEN ROB
Biginchhustler: is your air cleaner cover airbrushed or factory? I have a open spot on my right forearm ...would make a great tat..If you don't mind ;could I print it out, and give it to the Bro who does my ink....? And,...how long have you had those friends hanging around..........? ROTTEN ROB.........
Old Jan 4, 2014 | 04:56 AM
Rtlang's Avatar
Rtlang
The new carb is ordered and on the way! I'm excited to get this sumbitch going after so long in storage. Thanks for all the help!
When I pulled the manifold, I noticed this chip missing. The old o-ring was formed to the gap, so I'm assuming its been missing awhile. Any suggestions on this?
I've seen aftermarket kits to convert from o-ring to band type clamps. Anyone have any experience with this? There may be a thread on this already, I haven't looked yet.
