1967 electraglide front wheel
Old Apr 8, 2014 | 12:01 AM
5hands5's Avatar
5hands5
Default 1967 electraglide front wheel
I am trying to get my front wheel off my 67 electraglide. My problem is the hub cap! How is it attached? I can't seem to remove it. Any hints?
Old Apr 8, 2014 | 07:42 AM
johnjzjz's Avatar
johnjzjz
the axle slides through it - but no one leaves a little grease on the outside for it not to seize up - if your not carefull you can bend the threads on the axle
Old Apr 9, 2014 | 01:03 AM
5hands5's Avatar
5hands5
Default Hub cap
So what you are saying is that it may be seized on? Just so I am clear, there are no clips holding this cap on?
Old Apr 9, 2014 | 07:22 AM
johnjzjz's Avatar
johnjzjz
no and they can be a hand full to remove - heat it from the back side and wd40 it over night first
Old Apr 9, 2014 | 11:19 PM
5hands5's Avatar
5hands5
Thanks John! I'll let you know how it turns out.
Old Apr 10, 2014 | 11:47 PM
5hands5's Avatar
5hands5
Ok, this is how it went. I tried to tap it out &it wouldn't budge, so I took some tin snips to it & cut it out. After I got it out there was a spacer that would not let me remove the axle. I tried to move it with a monkey wrench but it wouldn't budge. Do I just hack jaw the axel off?
Old Apr 10, 2014 | 11:56 PM
FilthyLucre's Avatar
FilthyLucre
If you removed the axle cap you should be able to wiggle the axle out with the spacer still on. With the front wheel elevated you should be able to compress one slider enough to get it to clear. Did you try penetrating oil and heat first?
Old Apr 11, 2014 | 05:48 PM
sixty7flh's Avatar
sixty7flh
Default damn
This thread caught my attention as that year is the one I've had for 28 or so years now, (dammit, I'm getting old!). I never had an issue with mine, sorry I can't help ya. I imagine after it is out, it should be o.k the next and next time? If it's that hard it makes me wonder if it's ever been out. Hey. If you don't already, that "Parts Manual" is your best friend: Full of exploded views to show you just WHAT you are dealing with, or to put it back correct. I always seem to have mine out, right along side the service manual. Often I use it more...... hope it works for you. let us know...
Old Apr 13, 2014 | 02:11 AM
5hands5's Avatar
5hands5
Thanks for the input 67flh. I always have my Manuel at hand because I am no genius. John, I heated & wd'd but no luck. I decided to put a tie down on the right slider &bring it up a little and wala!!! It slid out like butta. Thanks for all your great input. New tires & brakes & I'm on the road.
Old Apr 13, 2014 | 02:15 AM
5hands5's Avatar
5hands5
Sorry filthy lucre, you were the one to tell me about lifting the slider. Thanks!!!
