Headlight
Old Jul 18, 2014 | 08:40 AM
berndog's Avatar
berndog
Default Headlight
So I installed a halogen h4 light,,but still need to rewire bike as wires are broken from switches to harness,,,hi beam works ,so my question is ,has anyone wired hi & lo beam together,,what were the results? and how did you do it?
Also is there any brighter bulbs anyone has used.
Old Jul 18, 2014 | 10:01 AM
panz4ever's Avatar
panz4ever
Never wired the two together, just one wire from the high beam to switch and one to ground
Old Jul 18, 2014 | 10:30 AM
SeaZund's Avatar
SeaZund
the headlight is the single biggest draw from your generator/alternator system; you'll be asking too much out of it through the regulator if you do this
Old Jul 18, 2014 | 09:33 PM
TwiZted Biker's Avatar
TwiZted Biker
Run the power for the headlight through a relay for the high/low don't go through the stock handlebar switches using a halogen light they pull too many amps, those little switches don't like that. Running both together will just shorten the bulb life and put a heavy draw on the electrical system . You can use a 3 position toggle switch without a relay if you have a place to mount it.
flhsport
EVO
11
Jul 31, 2016 06:23 PM
rags
Sep 29, 2015 05:17 PM
Veekness
Sep 29, 2014 07:26 AM
55chevy
Nov 15, 2011 10:55 PM
FUQUA
Feb 8, 2010 06:45 PM
