hey john
Old Aug 27, 2014 | 07:16 PM
biginchhustler's Avatar
biginchhustler
Default hey john
ok I know -- evo question -- but I need people who know --
I got this 1984 fxrs running -- when I look in the tank is see FOAM -- the lifters pumped up but when I take the return line off (not running) I see foam - I really don't see oil being pumped back into the tank but it sure is foamy -- it has the S&S 2 to 1 oil pump gears -- the S&S steel breather with the screen removed and the hoptop in it - the pump is a S&S pump -
when I took it apart I didn't find that plastic oil separator in the steel cam cover tube -
oil comes out the return when I disconnect and hook up a hose -- nothing but air from the breather vent no oil --
oil is the dino version of valvoline
Old Aug 27, 2014 | 08:15 PM
johnjzjz's Avatar
johnjzjz
your ok evo has a different breather system in that it is better at lubing everything with a air blown mist -- ( we believe its the distance and the angle in the evo block that cleans the wheels of excess oil in a different way than the older stuff / the plastc oil diverter was not factory installed till the 91 model - and foam returning is they way they work -
shovels like you already know had a solid liquid return till they get hot - than bubbles - if the evo has sumped a bit ( more common than the shovel ) it will liquid the start up but no worrys for me with that - did you go to the dark side NOw did you hahahahahhahaha
i own both hahahahahhahahaha
biginchhustler
Oil Archive (no new posts)
Aug 27, 2014 07:31 PM
lebert
May 29, 2010 10:17 PM
Van_Kerr
EVO
Dec 6, 2009 04:21 PM
lowglide88
Exhaust System Topics
May 5, 2009 11:56 PM
howiedodat
Apr 4, 2009 05:08 PM
