Runaway Starter
Old Apr 1, 2018 | 08:49 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Here ya go...
https://www.hdforums.com/forum/evo-c...ded-click.html
Old Apr 2, 2018 | 07:00 AM
gregjo1948's Avatar
gregjo1948
Thanks 98hotrodfatboy!!!! I found it. Looks like 2, of the same relays, wired correctly should turn power off to the starter as soon as the starter button is released. Am I right?
Thank you again, gregjo1948
Old Apr 2, 2018 | 07:06 AM
98hotrodfatboy
I was only showing you the link John was talking about. This is for the "Evo era, Dreaded Click Fix". Not sure it apply to your bike... John's wiring diagram is the fix for your problem..
Old Apr 9, 2018 | 05:26 PM
jluppert0521@gmail.com's Avatar
1st Gear
I had this problem...once, the 3 piece ring gear seperated and locked the starter clutch out...got lucky and got the battery disconnected before the starter burned out. Picked up a battery kill switch on Amazon, routed the main power to the solenoid through it. Same idea as the secondary solenoid, but manual. The "key" pops out when it's turned off and kills the bike, so it works as a trick anti theft as well
Old Apr 9, 2018 | 07:01 PM
johnjzjz's Avatar
johnjzjz
and then you could do this instead
Old Apr 12, 2018 | 11:33 AM
sleighcrane's Avatar
sleighcrane
I have a 67 sportster with no starter relay in the system and does not show it in the wiring diagram either and am thinking about adding the small Delco unit that they used in later years. I believe that this will be an added safeguard to my electric start system. Would I be correct? I don't think that I need the two relay system do I? Thanks
Old Apr 12, 2018 | 07:02 PM
johnjzjz's Avatar
johnjzjz
its either or -
falconbrother
EVO
11
May 20, 2016 06:18 PM
watindes
EVO
Jun 1, 2014 11:18 AM
goliath1
Dec 20, 2012 05:09 PM
ConRic72
May 15, 2010 09:18 AM
galtjunk
EVO
21
Dec 5, 2009 08:20 AM
